Yangtze River 1.5kW gasoline generator thyristor voltage regulating circuit
Source: InternetPublisher:司马缸砸光 Keywords: Generator thyristor voltage regulating circuit Updated: 2020/12/16
When the gasoline generator starts, press the start button SB, the magnetic field winding BQ
forms a loop through the diode VD4 and the current limiting resistor Rio, the excitation current increases, and the generator output voltage increases. When the voltage is close to the rated voltage
, release SB and the generator will enter the automatic excitation working state. In the figure, S is the demagnetization switch, which is demagnetized when it is turned off.
- How to use a microcontroller to control a servo motor?
- What is a 4-pin PWM header? How do 4-pin PWM fans work?
- Current output characteristics of brushed motor driver chips. How to increase the peak drive current?
- Peripheral circuit of automotive motor controller power supply chip
- Introduction to the internal structure of the Delta winding motor
- Working principle of one Xipu STR soft starter controlling two motors
- Motor self-starting circuit
- Design and production of wireless multi-location control switch circuit
- Audio interface protection circuit
- Guanghua brand anti-theft doorbell electronic lock circuit
- Rural fish farming control circuit
- Multi-channel patrol detection control circuit a
- Remote control receiving circuit of Panasonic inverter air conditioner indoor unit control circuit
- Paper tension control circuit
- Car window control circuit
- Table printing machine control circuit
- Lightning protection wiring of generator-transformer unit
- Generator longitudinal differential protection circuit with fast saturation converter
- Simultaneous merging route diagram
- Single-phase gasoline generator control circuit
