Optoelectronic relay circuit using operational amplifier
Source: InternetPublisher:清宁时光 Keywords: Optoelectronics operational amplifiers relay circuits BSP Updated: 2020/03/12
It uses an operational amplifier and a phototransistor VTi as the detection element. In the figure, Ra
is the feedback resistor, and its size determines the amplification factor of the operational amplifier; RP. It is the zero adjustment potentiometer; Cl and R. Complement the
taste with phase. If LM324 operational amplifier is used, Cl and R4 can be deleted.
When no light shines on the phototransistor VTi, pin 6 of operational amplifier
A outputs a high level, and the transistor VTz
guides the relay KA. When there is light, pin 6 of A outputs a low level, VT2 cuts off, and KA freed.
- Analysis of the working principle of car garage door lights
- Build a Smart Garage Door Opener Using a Raspberry Pi
- Peripheral circuit of automotive motor controller power supply chip
- One-way rotation circuit of motor controlled by contactor
- Design and analysis of a four-bit remote control component capable of remote reset
- Design and manufacture of three-phase motor protection circuit
- Audio interface protection circuit
- Electric vehicle battery charging protection circuit
- Guanghua brand anti-theft doorbell electronic lock circuit
- Delay switch made with LM431
- Set timing circuit when power is on
- Homemade disinfectant circuit
- Electronic anti-asthma circuit
- Fish pond oxygenation reminder circuit
- Fish farming thermostatic control circuit
- Diode Balanced Mixer Circuit
- Simple AGC circuit in transistor radio
- collector amplitude modulation circuit
- Double gate field effect transistor high frequency amplifier circuit
- Sine wave signal generator circuit
