12V Sealed Lead Acid Battery Dual Level Float Charger
Source: InternetPublisher:兰博 Keywords: charger Updated: 2024/07/11
When the 18V input voltage is added, the series power tube TIP42C is turned on and starts high-current constant-current charging. The charging current is 500mA. At this time, the charging current remains unchanged and the battery voltage gradually increases. When the battery voltage reaches 95% of the overcharge voltage Voc (i.e. 14.25V), the battery enters the overcharge state. At this time, the charging voltage is maintained at the overcharge voltage and the charging current begins to decrease. When the charging current drops to the overcharge termination current (IOCT), the 10th pin of UC3906 outputs a high level, the comparator LM339 outputs a low level, and the battery automatically enters the floating charge state. At the same time, the fully charged indicator light-emitting tube lights up, indicating that the battery is fully charged.
- Output large current regulated voltage adjustable power supply, 3~15V 10A adjustable regulated voltage power supply circuit diagram
- What is a battery management system? Analysis of the uses of power management systems
- A very convenient small power supply circuit to share
- INA155/INA156 is used to form a single-supply high-side current monitor for detecting load current
- Single-power supply circuit for ISO122P/ISO124
- BA6104 five-digit LED level meter driver integrated circuit basic application circuit
- Constant current LED lamp driver circuit with soft start and anti-shock
- How to use SBR to improve power conversion efficiency
- Miniature polarity reversal power supply using MAX1721
- Voltage-current converter constructed with XTR110
- 24V power supply pure flat display high voltage power supply circuit diagram
- Power circuit b composed of intelligent thyristor modules
- High current (4A) switching regulator integrated circuit L296 outputs 5.1 to 40V
- Commonly used power circuits in printers
- Power supply circuit with multiple outputs (MAX1902)
- Fully automatic two-stage constant current charger
- Fast charging charger
- Multipurpose constant current charger
- A charger in which the pulse charging current decreases exponentially
