Multifunctional protection circuit for detecting harmonic current
Source: InternetPublisher:吃掉星星 Keywords: Protection circuit harmonic current BSP winding Updated: 2020/11/12
It has phase failure and overload protection functions.
This circuit uses two sets of current transformers, 1TA1, lTA2, and lTAs are out-of-phase signal detection components; 2TA1,
2TAz, and 2TA3 are overload signal detection components. Adding winding ∞2 to the contactor KM coil instead of a transformer can save a
step-down transformer.
In the figure, the capacitor Cs acts as a delay for several seconds to avoid malfunction due to current impact during startup and to avoid
short-term overload current that occurs during normal operation of the motor.
Both sets of current transformers can be made of manganese-zinc MX0-2000 type magnetic surround. The secondary winding is wound with
about 500 turns of lacquered wire with a diameter of 0.2mm, and the primary winding is wound with 2 to 3 turns of power wire.
- The meaning and importance of circuit protection, common types of circuit protection
- How to remotely control devices using ESP8266 and LPC2148
- How to Build a Gesture-Controlled Elevator Prototype Using Arduino Nano
- A simple door handle touch alarm circuit
- How to set up a cheap beam break sensor control distance scene using a reflector
- Light-controlled circuit design and analysis
- Design and manufacture of three-phase motor protection circuit
- Design and production of no-load automatic power-off device for household power supply
- Motorcycle anti-theft device circuit design
- Homemade anti-theft watchdog
- Inpatient pager circuit
- Physiotherapy ventilator circuit
- Crop anti-frost circuit
- Agricultural spraying and insecticide control circuit
- Soil water shortage prompt circuit
- DC ammeter
- Electrical schematic diagram of DC voltmeter input at non-inverting terminal
- Double detuned loop frequency discriminator circuit
- Capacitive feedback oscillator circuit
- Common emitter-common base wideband amplifier circuit composed of F733 integrated amplifier
