Ultrasonic liquid level indication circuit diagram composed of NE555
Source: InternetPublisher:李商隐身 Keywords: NE555 circuit diagram ultrasonic routing Updated: 2021/08/31
The figure shows the ultrasonic liquid level indicating circuit composed of NE555 . The circuit consists of an ultrasonic transmitting circuit and a receiving circuit.
The ultrasonic transmitting circuit consists of 555, R1, W1, C1 and ultrasonic transmitting head UCM40T. The ultrasonic receiving circuit consists of a receiving head UCM40R that matches the transmitting head, cascade amplifiers BG1 and BG2, and a detection circuit. When the liquid level is close to the receiving head, the deflection angle of the voltmeter increases, and the closer the liquid level is, the greater the corresponding deflection angle is.
Since ultrasonic waves are not affected by the concentration and conductivity of the liquid being measured, this circuit is superior to the general contact liquid level display circuit and has higher accuracy.
ck="window.open(this.src)" alt="Click to see larger image"/>
- What is a photocoupler and how to select and use one?
- The unidirectional conduction current of the diode, the diode and its common uses
- Why do we need a MOSFET gate resistor? MOSFET Gate Resistor Placement
- Symbol/working principle/type/characteristics/application scenarios of depletion-mode MOSFET
- How to identify common mode interference? Methods to eliminate common mode interference
- Working principle and truth table of JK flip-flop
- Diode-based clipping circuit
- Beautiful crown wreath made with LED
- Introduction of TDA4863J/4863AJ TV field scanning IC
- LED lights that “drain” battery power
- Introducing the CD4013 washing machine timer circuit diagram
- One-digit display timer circuit diagram
- 220V welding machine wiring circuit diagram
- Inspection circuit diagram for broken rotor bar of three-phase motor
- NE555 exponential voltage controlled oscillator circuit diagram
- Make strobe light with NE555
- Use NE555 to make a three-way lantern controller
- Use NE555 to create touch and voice-controlled dual-function delay lights
- Nickel-cadmium battery fast charger circuit diagram using NE555
- Pulse width modulation switching regulated power supply circuit diagram composed of NE555
