Using CD4013 to implement dual-function button circuit
Source: InternetPublisher:他们逼我做卧底 Keywords: CD4013 switch circuit Updated: 2024/06/19
Usually, when we require an operating button to realize two functions in an application, we mostly have to rely on a single-chip microcomputer to complete it. In the absence of a single-chip microcomputer, we have to use two buttons separately, or adopt double-pole switching and other methods.
Here we introduce a circuit composed of triggers, which can realize the dual functions of power on/off by operating the key for a certain period of time, and can be used in many small game machine circuits. The circuit is shown in the figure below.
In the figure, the incandescent lamp HL replaces the electrical equipment. When SB is pressed, R1, C1 and R3, C2 form two integration circuits. According to the characteristics of the CD4000 series, when the potential of the CLK (pin 3 of CD4013) and R (pin 4 of CD4013) ends rises to 1/2∞, the output end of CD4013 changes, and the time when the CLK end arrives is t1 after SB is pressed, and the time when the R end arrives is t2 after SB is pressed. From the above figure, we have:
t1=R1C1In2=1(s)
t2=R3C2In2=2.29(s)
That is: when SB is pressed for time t1<t<t2, after CD4013 receives the signal sent by SB at the CLK and D terminals, it makes its 2nd pin low level to turn on VT; when SB is pressed for time t2<t, VT is turned off.
- How to choose the right level of integration to meet motor design requirements?
- How to remotely control devices using ESP8266 and LPC2148
- Peripheral circuit of automotive motor controller power supply chip
- Controlling LEDs with Multithreading via Dual-Core Programming on Raspberry Pi using MicroPython
- Replace the GE LOGIQ a200 ultrasound measurement key with a self-made touch switch
- Simple phase failure protection circuit composed of intermediate relay
- Hydraulic control circuit design and analysis
- Infrared blocking alarm device
- Ultra-short wave item left behind reminder alarm
- Infrared detection alarm
- Mos tube switch circuit diagram
- Light control switch circuit
- Ventilation fan infrared remote control switch circuit
- Sound control power saving switch circuit
- FM modulator strong-weak signal switching circuit a
- Photoelectric control switching circuit composed of photoresistor lamp elements
- Use 1 PS3001 light control switch
- FGDF-3 type three-phase low-temperature iron-plated power supply commutation control and electronic transfer switch circuit
- Lighting sound and light switch circuit 2
- Light control switch circuit controlled by flashlight 2
