elleny
MAXREFDES36#: 16-channel IO-LINK digital input hub
Programmable logic controllers (PLCs) and distributed control systems (DCS) use more digital input signals than any other combination of input signal types. Parallel connection of industrial digital input cables to a PLC is not only expensive, but also tends to create a rat's nest of wiring that is difficult to maintain. Fieldbus greatly improves this situation by moving the I/O interface from the PLC to a remote I/O hub near the on-site sensors . However, the lack of a single, universally accepted fieldbus also creates confusion, training challenges, high costs, and compatibility issues between devices1 .
IO-Link is the first open, fieldbus-agnostic, low-cost, point-to-point serial communication bus protocol for communicating with sensors and actuators that has been adopted as an international standard (IEC 61131-9) 2 . IO-Link finally standardized the interoperability of industrial equipment around the world. IO-Link can be operated directly from a PLC or integrated into any standard fieldbus, making it quickly becoming the de facto standard for communicating with smart devices such as the MAXREFDES36#.
MAXREFDES36# is a 16-channel IO-Link digital input hub mounted on a small 53.75mm x 72mm printed circuit board (PCB). Maxim Integrated and Technologie Management Gruppe Technologie und Engineering (TMG TE) collaborated to design MAXREFDES36# as a digital input hub reference design compatible with version 1.1/1.0 of the IO-Link protocol . The MAXREFDES36# design includes industry-standard Maxim Integrated IO-Link device transceiver ( MAX14821 ); high-efficiency, high-voltage, step-down converter ( MAX17552 ); Renesas® ultra -low-power, 16-bit microcontroller (RL78), Uses TMG TE's IO-Link device stack and two Maxim Integrated digital input serializers ( MAX31913 ). Figure 1 shows the system block diagram.
Figure 1. MAXREFDES36# reference design block diagram.
characteristic
  • DIN rail design
  • IEC 61131-9
  • Compatible with IO-Link versions 1.1 and 1.0
  • On-chip 8:1 serialization
  • Fault monitoring
  • Field powered LED driver
Competitive Advantage
  • Small size
  • Low power consumption
  • low cost
application
  • PLC digital input module
  • production line
  • Conveyor system
  • robot
  • process control and automation
  • automated industry
  • PLC and DCS systems
参考设计图片
Search Datasheet?
Forum More
Update:2025-07-28 05:40:50
