3228
PALO VERDE (MAXREFDES33#): Buck Converter
The Palo Verde (MAXREFDES33#) subsystem reference design (Figure 1) demonstrates the application of the MAX15062A 60V, 300mA, ultra-small, high-efficiency, synchronous buck converter. The reference design operates over a wide input voltage range of 4.5V to 60V and provides up to 300mA @ 3.3V output. The device features undervoltage lockout, overcurrent protection, and thermal shutdown. The MAX15062A's switching frequency is fixed at 500kHz, and a maximum efficiency of 86.77% can be achieved with the supplied components when the input is 24V. This universal power solution can be used in many different types of applications, such as 4–20mA current loop, HVAC and building controls, high voltage LDO replacement , universal point of load, and more. In this reference design, MAX15062 supports 24V input applications, such as industrial sensors , process control, etc.
System Block Diagram
Typical industrial control power system block diagram
Figure 1. Block diagram of a typical industrial control power system.
characteristic
application
  • Minimal peripheral components and low system cost
  • Versatility reduces DC-DC power supply count
  • Low power consumption
  • Works reliably in harsh industrial environments
  • Pmod™ Compatible Specifications
  • Industrial sensors
  • process control
  • 4–20mA current loop
  • Universal point of load power supply
  • Replace high voltage LDO
  • HVAC and building controls
  • PLC
参考设计图片
Search Datasheet?
Forum More
Update:2025-08-01 23:01:32
