qoistoochee128
Corona (MAXREFDES12#): Isolated, eight-channel, industrial digital input level translator/serializer
more pictures
Industrial control , industrial automation, motor control and process automation applications often require binary/digital sensors and switches, and the system often requires many optocouplers to isolate sensor channels. The Corona (MAXREFDES12#) subsystem reference design provides front-end interface circuitry for programmable logic controller (PLC) digital input modules. This serialization feature greatly reduces the number of isolation optocouplers. The reference design supports high voltage input (up to 36V), power and data isolation - all in a small package. The Corona design integrates an eight-channel digital input level translator /serializer ( MAX31911 ), data isolator ( MAX14850 ), and H-bridge transformer driver ( MAX13256 ) for isolated power supply design. Corona digital input circuit solutions are mainly used for digital input modules in PLC, industrial automation, process automation and motor control applications.
Figure 1. The Corona subsystem design block diagram.
Figure 1. Corona subsystem design block diagram
characteristic
application
  • Eight high-voltage input channels (up to 36V)
  • On-chip 8-1 serializer, SPI interface
  • Internal 5V regulator
  • Isolate power and data
  • Small size printed board (PCB) area
  • Device driver
  • C language source code example
  • Pmod™ Compatible Specifications
  • Building automation
  • PLC digital input module
  • automated industry
  • motor control
  • process automation
Search Datasheet?
Forum More
Update:2025-07-27 11:09:43
  • Texas Instruments' first integrated ultrasonic T/R switch
  • S3C2440 65x45mm core board circuit diagram
  • Problems encountered in Keil
  • nor flash erase
  • TI C6000 Series Pipeline Concept
  • Regarding some issues with ERC checking in DXP, thank you for your help! ! Urgent~~
