containsmachine
Selecting the SPI clock mode for the MAXQ2000 microcontroller and MAX1132 ADC interface
MAX1132 Description
The MAX1132 is a 200ksps, 16-bit ADC. The MAXQ2000 can interface with the MAX1132 using different clock modes: 8-bit, 16-bit, or a combination of both. To optimize ADC performance, it is important to decide which mode to use during the initial stages of development. Obviously, a 16-bit ADC with 16 clock cycles per frame should be in 16-bit mode; however, in the specific case of an ADC with 24 clock cycles per frame, the SPI clock mode must be carefully evaluated. This application note provides test results using 8-bit, 16-bit, and a combination of the two modes. According to the results, it can be seen that when the MAX1132 uses a 24-clock frame format, the best performance can be obtained by using the combination mode.
Hardware description
This application circuit is implemented using the MAX1132 evaluation board and the MAXQ2000 evaluation board.
Figure 1 shows the MAX1132 evaluation board schematic, and Figure 2 shows the system configuration. To connect the MAX1132 EV kit to the MAXQ2000 EV kit, connect the SCLK, /CS, DOUT, and DIN pins on the MAX1132 EV kit to the MAXQ2000 EV kit, as shown in Figure 2. In addition, connect a +5V power supply to the AV DD and AGND ports on the evaluation board . JU1 of the evaluation board must be installed in the 1–2 (ON) position. Connect the analog signal up to +12V on JU2 and leave the other jumpers open. To ensure proper system operation, SW3 of the MAXQ2000 evaluation board must be turned off.
Figure 1. MAX1132 Evaluation Kit Schematic
Documentation
Search Datasheet?
Forum More
Update:2025-08-12 23:49:47
