3228
45W/12V power supply based on STCH03 QR flyback controller and SRK1000B adaptive synchronous rectification controller
EVAL-STCH03-45W
The EVAL-STCH03-45W is a 45 W / 12 V isolated power supply developed for general purpose applications. The evaluation board implements a Quasi Resonant flyback converter based on the STCH03 controller with optocoupler feedback for voltage and primary side regulation for constant output current regulation.
The secondary side rectification is based on the SRK1000B adaptive synchronous rectification controller.
The efficiency of the application is very high over entire output power range thanks to the smart power management of the STCH03 and SRK1000B controllers, the STF10LN80K5 MDmesh K5 primary MOSFET and the STL90N10F7 Power MOSFET for the synchronous rectification.
The evaluation board implements a robust output supply protected against output overvoltage, output undervoltage, output overpower and output short-circuit. The protections are auto-restart for a safe operation.
Main features
  • Input voltage range VIN: 90 VAC to 265 VAC
  • Output range: 12 V - 3.75 A continuous operation
  • Very low stand-by power:
  • Average full load efficiency:
    • > 88% @ 115 VIN
    • > 89% @ 230 VIN
  • Active mode at 10% load efficiency:
    • > 84% @ 115 VIN
    • > 82% @ 230 VIN
  • Active mode at 10% load efficiency: > 84% @ 115 VIN > 82% @ 230 VIN
  • Safety: Acc. to EN60065
  • EMI: Acc. to EN55022 - Class B
  • Small PCB form factor: 85 x 55 X 25 mm
参考设计图片
Search Datasheet?
Forum More
Update:2025-08-08 12:47:40
  • Design of information processing and monitoring system for modern elevators
  • CC2530 wireless lighting experiment
  • About Kalman Filter Algorithm
  • Very good DSP introductory material (I)
  • Fortune China: The Secret of Huawei
  • Frequency Response of an RC Low Pass Circuit
