containsmachine
15kW Vienna-style three-phase rectifier with low-cost mixed-signal control for power factor correction
STDES-VIENNARECT
As a complete solution, this reference design targets high-power three-phase AC/DC rectification applications based on Vienna topology. The main feature is mixed signal control. The STNRG388A controller provides digital output voltage regulation, and the dedicated analog circuit provides high-bandwidth continuous conduction mode (CCM) current regulation to maximize total harmonic distortion (THD) and power factor (PF).
The high switching frequency and multi-level structure based on SiC MOSFETs (70 kHz) enable efficiencies of nearly 99% while optimizing passive components in terms of size and cost.
This high efficiency Vienna rectifier is designed for several end applications requiring high PF and low THD, such as electric vehicles (EV), industrial battery chargers and industrial equipment
Main features
  • Three-phase three-level bidirectional AC/DC converter
    • Rated nominal output DC voltage: 800 V DC
    • Rated nominal input AC voltage: 400 V AC /50 Hz
    • Nominal output power AC/DC: 15kW
    • Power factor, PF > 0.99
    • Inrush current control and soft start
    • THD is less than 5% during normal operation
  • Power devices based on SiC MOSFETs and diodes:
    • High frequency operation (70 kHz)
    • High peak efficiency is greater than 98%
    • Passive component weight and size reduction
  • Control device using programmable STNRG388A digital controller
    • Low cost mixed signal control
  • Overcurrent and overvoltage protection
参考设计图片
Search Datasheet?
Forum More
Update:2025-07-18 04:57:40
