fish001
USB Type-C Power Delivery Dual Function Power (DRP) and Dual Function Data (DRD) expansion board based on TCPP03-M20 for STM32 Nucleo
X-NUCLEUS-DRP1M1
The X-NUCLEO-DRP1M1 expansion board allows evaluation of the features of the TCPP03-M20, as well as the required USB Type-C™ features and protection for VBUS and CC lines for dual function power supply (DRP) applications.
[X-NUCLEO-DRP1M1 IMAGE]
The expansion board can be stacked on top of any STM32 Nucleo-64 whose microcontroller has embedded Power Delivery (UCPD) peripherals.
Thanks to the integrated ST715PU33R LDO linear regulator powering the connected STM32 Nucleo development board, the X-NUCLEO-DRP1M1 effectively demonstrates "dead battery" and charging operations. It also demonstrates USB Type-C™ powered operation when a compatible external power source is connected to the board.
In addition, the expansion board allows dual data functionality of the powered device.
The X-NUCLEO-DRP1M1 complies with USB Type-C™ and Power Delivery Specification 3.1 Standard Power Range (SPR) and is USB-if certified as a 100 W DRP solution supporting Programmable Power Supply (PPS).
The accompanying software package (X-CUBE-TCPP) contains application examples for development boards with embedded UCPD-based microcontrollers (NUCLEO-G071RB, NUCLEO-G474RE and NUCLEO-G0B1RE).
All features
Supports all USB Type-C™ Power Delivery SPR profiles (up to 100 W)
Manage dual role data/power configuration
Based on STM32 USB data processing capabilities, compliant with USB 2.0 Dual Role Data standard
8/20 μs surge, VBUS pass Voltage protection, overcurrent protection, and
VBUS short-circuit protection on discharge CC1 and CC2 configuration channel pins
ESD protection for CC1, CC2, D+, and D- (conforming to IEC61000-4-2 level 4 ± 8 kV contact discharge standard)
for VCONN overvoltage protection, overcurrent protection, and discharge
Common mode filter for D+/D- data lines
Three power modes to optimize current consumption
Compatible with programmable power supply (PPS)
Free comprehensive development firmware library
Compatible with STM32 Nucleo-64 board (equipped with STM32 with UCPD function)
参考设计图片
Search Datasheet?
Forum More
Update:2025-08-06 00:34:42
