张小哥
65W USB-PD switching power supply reference design using XDPS21081
REF_XDPS21081_65W1
This is a reference design for a 65W USB-PD type C charger with a small form factor. Reference designs are designed to demonstrate performance by meeting various industry specifications and allowing for small form factor design requirements. Using Infineon digital flyback controller XDPS21081, 600V CoolMOS™ C7 superjunction MOSFET (IPL60R185C7), OptiMOS™ PD synchronous rectification MOSFET (BSC0802LS), 30V OptiMOS™ MOSFET (BSZ0905PNS) as a safety switch, small signal MOSFET (BSL606SN) and the EZ-PD™ CCG3PA USB Type-C controller.
This 65W USB-PD3.0 type C charger has a universal input voltage range of 90~264 VAC. The supported output voltages are 5V/3A, 9V/3A, 12V/3A, 15V/3A, 20V/3.25A. It has a peak efficiency of 93% and low standby input power of less than 65mW.
Feature description
Universal input voltage range 90~264VAC
continuous power up to 65W, with peak efficiency greater than 93%
Fixed output: 5V/3A, 9V/3A, 12V/3A, 15V/3A, 20V/3.25A
compliant with EU CoC Level 2 and US DoE Energy Star Level VI average efficiency and no-load input power requirements
Advantage
Easy to customize, compact appearance,
high efficiency, low standby power consumption, meeting international industry standards
Potential applications
USB-PD
charging
consumer products
power
参考设计图片
Search Datasheet?
Forum More
Update:2025-08-08 23:22:06
