张三叔
Turnkey reference design kit for low voltage, high performance, high efficiency and high speed PMSM/BLDC motor drive applications
REF-VACUUM_C101_2ED
Turnkey reference design kit for low voltage, high performance, high efficiency and high speed PMSM/BLDC motor drive applications is a reference design kit using the IMC101T iMOTION controller, 2ED2304 SOI half-bridge gate driver and BSC030N04NS OptiMOS. This reference design kit showcases our thin-film SOI and advanced motion control engine (MCE 2.0) technology enabling drive speeds up to 120KRPM for low-voltage permanent magnet motors, while the inverter section is rated up to 30 V and 25 A. It has been optimized for low voltage appliances such as vacuum cleaners, fans, pumps, compressors and other low voltage motor drive applications.
Feature description
  • Input voltage 18~30V DC
  • Maximum 25A 600W at 24V DC power input, equipped with onboard cooling fan
  • Anti-reverse connection protection
  • VSP speed command potentiometer
  • 3 digital Hall interfaces
  • User UART for script functions
  • Over current and over temperature protection
  • Fault diagnosis LED output
  • Low Noise Single Shunt Current Sampling
  • Auxiliary power supply adopts 12V, 3.3V
  • Board size: 60 mm × 115 mm, 1oz copper thickness, 2-layer PCB (or, without fan: 60 mm × 63.5 mm)
  • RoHS compliant
  • Main features of 2ED2304S06F
    • Infineon Thin Film SOI Technology
    • Fully supports +650 V bias voltage
    • Integrated ultra-fast, low on-resistance bootstrap diode
    • Output source/sink capability is +0.36 A/-0.7 A
    • Withstands negative transient voltages up to -100 V (pulse width increased by 300 ns) due to SOI technology
    • Gate drive voltage range is 10 to 20 V
    • Independent undervoltage lockout (UVLO) for both channels
    • Short propagation delay and delay matching (60 ns maximum)
    • Schmitt trigger input with hysteresis and pull-down
    • 3 V, 5 V and 15 V input logic compatible
  • Main features of IMC101T-T038
    • Highly integrated variable frequency drive solution
      • Integrates all digital and analog components
      • No external op amp or comparator required
      • 3 V or 5 V supply voltage
    • Next generation motion control engine (MCE 2.0)
      • Mature calculation engine for high-efficiency sine wave motor control
      • Single resistor or bridge arm resistance sampling
      • Sensorless or optional Hall sensor support
      • Flexible host interface/control options
    • Integrated protection features
    • Multi-motor support with flexible parameter processing features
  • Main features of BSC030N04NS G
    • Excellent gate charge x RDS(on) product (FOM)
    • On-resistance RDS(on) is very small
    • Suitable for fast switching applications
    • RoHS compliant—halogen-free
参考设计图片
Search Datasheet?
Forum More
Update:2025-08-08 18:59:57
