smallembedded
65W USB-C power adapter solution using EZ-PD™ PAG1
VD_USB_PAG_65W_ADAPTER
The 65W power adapter reference design is based on the EZ-PD™ PAG1s and PAG1P controllers. The solution complies with international energy efficiency standards including DoE Level 6/CoC Level 2 and passes conducted emissions testing as specified in the EN 55032 B standard. This solution is designed for use with USB-C PD (including PPS), QC power adapters. Adapters covering traditional charging protocols including Apple Charging, BC1.2, QC 3.0 and Samsung AFC are also supported. PAG1S and PAG1P together provide low BOM cost and high-performance solutions compatible with PD/PPS/QC.
Reference design features
  • Support USB PD 3.0
  • Fixed PDO: 5 V/3 A, 9 V/3 A, 12 V/3 A, 15 V/3 A, 20 V/3.25 A
  • PPS: 3.3V-21V/3A
  • Compliant with CoC Level 2 and DoE Level 6 energy efficiency standards
  • Complies with CE standards defined according to EN55032 B
  • Low cost BOM, includes a simple primary startup controller (PAG1P) and an integrated SR+PD controller (PAG1S)
Search Datasheet?
Forum More
Update:2025-08-08 05:04:41
  • Thank you for being here-Community Activities
  • 100 points for help regarding touch screen, handwriting software, operation speed...
  • atmega161 color screen mp3 schematic diagram + C language source program
  • 2016-2017 New Year's Eve
  • About adding commands in U-boot
  • Job search embedded development
