蓝猫淘气
65W USB-PD/PPS power adapter solution using EZ-PD™ PAG1 and CoolGaN™
VD_USB_PAG_65W_COOLGAN
This 65W Type-C PPS reference design uses Infineon's EZ-PD™ PAG1S and PAG1P controllers and CoolGaN™ 600V GIT HEMT. The solution complies with international energy efficiency standards including DoE Level 6/CoC Level 2 and has low standby power. The solution is tested to CE standards defined by CISPR32 Class B and provides a high board-side power density of 22.16 W/in3. This solution is designed for use with USB PD (including PPS), QC power adapters. Adapters covering traditional charging protocols including Apple Charging, BC1.2, QC 3.0 and Samsung AFC are also supported. PAG1S and PAG1P jointly provide low BOM cost, high-performance solutions compatible with PD/PPS/QC. Reference design features:
  • Universal input voltage: 90V AC  – 265V AC
  • Support USB PD 3.0
  • Fixed PDO: 5V/3A, 9V/3A, 12V/3A, 15V/3A, 20V/3.25A
  • PPS: 3.3V-21V/3.25A
  • Board size: 52x42x22 mm 3
  • Compliant with CoC Level 2 and DoE Level 6 energy efficiency standards
  • Complies with CISPR 32 Class B CE standard
  • Low cost BOM, includes a simple primary startup controller (PAG1P) and an integrated SR+PD controller (PAG1S)
Search Datasheet?
Forum More
Update:2025-08-04 08:33:16
