qoistoochee128
43 W high power factor constant voltage output flyback converter based on ICL8800
REF_ICL8800_LED_43W
REF_ICL8800_LED_43W This 43 W reference design uses Infineon's high power factor flyback controller ICL8800. The evaluation board is a constant voltage (CV) secondary side regulation (SSR) system designed for use with a constant current (CC) converter for LED lighting applications.
Two-stage topologies are becoming increasingly popular due to the easy scalability of primary-side power and secondary-side characteristics. The REF_ICL8800_LED_43W solution features a plug-and-play design and can be used with the secondary-side DC/DC evaluation board.
As a default, the reference design board is equipped with a depletion mode MOSFET BSS126I based startup circuit on a small adapter board. This setup will significantly reduce standby losses. If low standby power consumption is not required, the startup circuit can be changed to a resistive startup design.
This reference design comes with two conditioning circuits. Both are plug-and-play solutions, but at least one circuit must be connected to the motherboard. There is a cost trade-off between the two evaluation boards; the TL431 evaluation board is lower cost and has good standby performance, while the op amp board exhibits excellent overall performance at the 30 mW power level.
Feature description
  • Constant Voltage (CV) Secondary Side Regulation (SSR) Reference Design for LED Lighting Applications
  • Power factor (PF) > 0.9 and THD < 10%, applicable to a wide load range (AC input up to 277 V rms )
  • Maximum AC input voltage: 90 – 305 V rms
  • Critical conduction mode and quasi-resonant mode supporting smart valley jumping
Advantage
  • Ideal topology for LED on/off drivers with a minimum dimming level of 5%
  • Two-level topology that combines scalability and functionality
  • Super high gloss quality
  • Cost-effective bottom-up design
  • High flexibility, low material cost, suitable for a variety of applications
Potential applications
LED lighting
Dimmable LED driver with dimming function
LED driver and lamp
adapters and chargers up to 125 W, flat screen TVs, all-in-one PCs, monitors up to 125 W
参考设计图片
Search Datasheet?
Forum More
Update:2025-08-04 05:02:29
