蓝猫淘气
Integrated Turnkey Reference Design for Rotary Refrigerator Compressor Drive
REF-MHA0K2IMC101T
REF-MHA0K2IMC101T provides an easy-to-use solution for effectively controlling refrigerator compressors. It uses the iMOTION™ IMC100 motor controller IMC101T-T038 to provide a ready-to-use motor control solution, where the CIPOS™ Micro 600 V, 6 A three-phase IPM (IM241-L6S1B) helps achieve high integration. The design can be easily copied to the final mass production board, accelerating the time to market. This reference board is the next generation product that succeeds the REF_FRIDGE_C101T_IM231. Features Up to 200W maximum power, no heat sink required CIPOS™ Micro IPM based on 2nd generation RCD2 reverse conducting IGBTs Accurate overcurrent protection (±5%) and built-in temperature sensor MCE 2.0 firmware B-level pre-certification (IEC60335) Benefits Turnkey motor control based on iMOTION™ controller and motion control engine (MCE 2.0) High speed Accuracy +/-0.6% with torque compensation Vibration suppression High integration, based on IM241-L6S1B, built-in overcurrent protection and UL certified temperature sensor
参考设计图片
Blockdiagram
Search Datasheet?
Forum More
Update:2025-07-20 07:18:40
