张三叔
15W 5 V USB Adapter Reference Design Board Using Quasi-Resonant PWM IC ICE2QS03G and CoolMOS IPS65R 1 K5CE
REF-15W_IR_OPTI3
This is a 15W 5V USB adapter reference design board using quasi-resonant PWM IC ICE2QS03G (DSO-8) with CoolMOS™ IPS65R1K5CE (IPAK SL) and secondary side synchronous rectification with OptiMOS™ BSZ100N06LS3G (S3O8, 3x3 mm style SuperSO8) IR1161 (5-pin SOT-23). Designed for high-reliability systems, this reference USB adapter board features a compact form factor, high efficiency, low standby power, various protection methods, and passes conductive electromagnetic interference, ESD, and lightning shock wave testing. Customers only need to make slight changes to this board, and it can be used for production after final confirmation.
Feature description
  • Quasi-resonant flyback with advanced CoolMOS - high efficiency and low EMI noise
  • Active burst mode with high voltage start-up unit and very low standby power consumption
  • Secondary side synchronous rectification controller, with advanced OptiMOS, further improves efficiency
  • Various protection modes and rugged CoolMOS - high reliability system
Advantage
  • Very compact form factor
  • high efficiency
  • Best-in-class low standby power
  • Good electromagnetic interference performance
  • Various protection modes realize high reliability system
Potential applications
  • power supply
参考设计图片
Search Datasheet?
Forum More
Update:2025-08-08 08:17:03
