石榴姐
【CW32】BLDC
Brushless driver board
Typical MOS driver + three-phase bridge,
PCB design instructions
Nothing to pay attention to. Remember to lay wider copper in the high-current part of the MOS driver and use more Via for heat dissipation.
Software description
Upper tube modulation, lower tube switch;
void Commutation(unsigned int step,unsigned int OutPwmValue,unsigned int PWM_ON_flag)
if(PWM_ON_flag==0) //Turn off output if not started
CW_ATIM->CH1CCRA=0;CW_ATIM->CH2CCRA=0;CW_ATIM->CH3CCRA=0;//Timer output comparison is set to 0
ATIM_CtrlPWMOutputs(DISABLE);
PWM_AL_OFF; PWM_BL_OFF; PWM_CL_OFF;
return;
//Output PWM to the upper bridge, example: AB means (A upper bridge is on, B lower bridge is on)
if(step==0||step==1){CW_ATIM->CH1CCRA=OutPwmValue; CW_ATIM->CH2CCRA=0; CW_ATIM->CH3CCRA=0; } //0:AB; 1:AC
if(step==2||step==3){CW_ATIM->CH1CCRA=0; CW_ATIM->CH2CCRA=OutPwmValue; CW_ATIM->CH3CCRA=0; } //2:BC; 3:BA
if(step==4||step==5){CW_ATIM->CH1CCRA=0; CW_ATIM->CH2CCRA=0; CW_ATIM->CH3CCRA=OutPwmValue;} //4:CA; 5:CB
//Control IO lower bridge
if(step==0||step==5){PWM_AL_OFF; PWM_CL_OFF;PWM_BL_ON;} //AB CB; B lower bridge is turned on
else if(step==1||step==2){ PWM_AL_OFF; PWM_BL_OFF; PWM_CL_ON;}//AC BC; C lower bridge is on
else if(step==3||step==4){ PWM_BL_OFF; PWM_CL_OFF; PWM_AL_ON;}//BA CA; A lower bridge is on
ATIM_CtrlPWMOutputs(ENABLE); //The output is valid
HALL sensed phase change
void GTIM2_IRQHandler(void)
unsigned int x;
/* USER CODE BEGIN */
if (GTIM_GetITStatus(CW_GTIM2, GTIM_IT_CC1))
GTIM_ClearITPendingBit(CW_GTIM2, GTIM_IT_CC1);
if (GTIM_GetITStatus(CW_GTIM2, GTIM_IT_CC2))
GTIM_ClearITPendingBit(CW_GTIM2, GTIM_IT_CC2);
if (GTIM_GetITStatus(CW_GTIM2, GTIM_IT_CC3))
GTIM_ClearITPendingBit(CW_GTIM2, GTIM_IT_CC3);
HALLcount++; //Hall pulse count
x=HALL_Check(); //According to the Hall count value, the status
Cur_step=STEP_TAB[x-1]; //Get the commutation sequence bit
if(Motor_Start_F==1&&ErrorCode==0) //Change phase according to start and stop status
Commutation(Cur_step,OutPwm,Motor_Start_F);
/* USER CODE END */
After the non-sense driver is completed, the code will be compiled and open sourced
Physical display instructions
Because it is a verification board, it is my first time to make a brushless motor driver, so the drawing is more casual and larger. The size will be compressed in the second version later;
ad9173aa-50e7-4bc2-8e35-9711d9b46a6e.jpgthing
参考设计图片
Search Datasheet?
Forum More
Update:2025-08-05 05:58:05
