3228
18650 charger based on TP5000
A 18650 charger based on TP5000, the cut-off voltage can be selected by a toggle switch, and supports charging of 4.2V and lithium iron phosphate batteries.
62054
Bingdundun key chain
Introduction: Bingdundun keychain 7.9*7.9cm
Bingdundun key chain DIY
Gerber_bingdundun.zip
BOM_bingdundun.csv
BOM download
PCB_bingdundun_2022-09-22.pdf
PCB_bingdundun_2022-09-22.json
Bingdundun_2022-09-22.pcbdoc
Gerber_bingdundun_2022-09-22.zip
62055
[Internet of Things] Hongmeng Smart WIFI Switch +4212619A
Introduction: Based on HiSilicon Hi3861 chip, intelligent WIFI switch
Based on HiSilicon Hi3861 chip, smart WIFI switch
VID_20220404_185929.mp4
BOM download
PCB_Hongmeng Smart WIFI Switch_PCB_2022-09-22.pdf
PCB_Hongmeng Smart WIFI Switch_PCB_2022-09-22.json
Hongmeng Smart WIFI Switch_PCB_2022-09-22.pcbdoc
Gerber_Hongmeng Smart WIFI Switch_PCB.zip
Schematic_[Internet of Things] Hongmeng Smart WIFI Switch +4212619A_2022-09-22.pdf
SCH_[Internet of Things] Hongmeng Smart WIFI Switch +4212619A_2022-09-22.json
Hongmeng Smart WIFI Switch_Schematic Diagram_2022-09-22.schdoc
62056
[Internet of Things] Hongmeng IoT Smart WIFI Switch
Introduction: Hongmeng Smart WIFI Switch
Use the Hongmeng Hi3861 chip combined with the servo to achieve WIFI remote control of physical switches in your home or dormitory.
VID_20220407_122241.mp4
BOM download
PCB_PCB_[Internet of Things] Hongmeng IoT Smart WIFI Switch_2022-09-22.pdf
PCB_PCB_[Internet of Things] Hongmeng IoT Smart WIFI Switch_2022-09-22.json
PCB_[Internet of Things] Hongmeng IoT Smart WIFI Switch_2022-09-22.pcbdoc
Gerber_PCB_[Internet of Things] Hongmeng IoT Smart WIFI Switch_2022-09-22.zip
Schematic_[Internet of Things] Hongmeng IoT Smart WIFI Switch_2022-09-22.pdf
SCH_[Internet of Things] Hongmeng IoT Smart WIFI Switch_2022-09-22.json
Sheet_1_2022-09-22.schdoc
62057
STLINK-V2.1 with virtual serial port VCP
Introduction: The board drawn by Lichuang Open Source stlink-v2.1 with virtual serial port is too big and not good-looking, so I draw a smaller one myself.
There was a zz error in the cover photo, which has been corrected in the shared file.
Attached is the stlink firmware with VCP
STLinkV2.J28.M18.bin
BOM download
PCB_PCB_STLINK_2022-09-22.pdf
PCB_PCB_STLINK_2022-09-22.json
PCB_STLINK_2022-09-22.pcbdoc
Gerber_PCB_STLINK.zip
Schematic_STLINK-V2.1 with virtual serial port VCP_2022-09-22.pdf
SCH_STLINK-V2.1 with virtual serial port VCP_2022-09-22.json
ST-LINKV2.1-USB male_2022-09-22.schdoc
62058
Cat.1 DTU extended version
Introduction: With 485 interface, Quectel EC600N-CN module is used as the communication module, and a 20pin custom interface is reserved.
As I wrote before,
this thing is actually my graduation project, but it is just for graduation. It is very simple 7a563ec9b2cac30a7966baecfd7ecde.jpgand what function does it have?
There is a 485 interface, using the SP3485 chip. Friends who know how high the differential voltage of this thing can be can comment below wwwwww.
There is an onboard interface that is directly compatible with the EC600N-CN module (it seems to be called Jiang or something? Just go to the Quectel Taobao store), plug it in and use it.
It has a battery power interface and an independent switch (wide voltage input, AMS1117-5 solution).
It has a serial port. Generally, the CH340G
does not have many things, but it is very practical. It is great for IoT development. There is
a 20-pin customization reserved on the right side. I originally wanted to use this thing as a TFT interface, but later I found that this thing is much more practical than TFT. What can I do with this thing? No hhhhh
Is there a BUG?
Yes, there was an error on the serial port side, but it is a good solution.
Do not solder D5D6 when soldering. Only solder R19 on the left side (stand it up). Just fly the wire on the right side of the resistor to the lower pin of D5.
See the picture 7a5f5c6718363e57a01d05310f07a78.jpgof the cute little red fly The
scalability of the cable (dense fog)
is very good. I have pins on both sides. I want to do whatever I want. How can I get the
source code
library of EC600N-CN? Please message me privately for
version update .
The next goal is to have no cavities
. Modify the hardware. Defect
Added Boost Module
Added Burner (daplink)
Shell DXF File See Attachment
Acrylic cover.dxf
BOM download
PCB_PCB_Graduation Project_2022-09-22.pdf
PCB_PCB_Graduation Project_2022-09-22.json
PCB_Graduation Project_2022-09-22.pcbdoc
Gerber_PCB_Graduation Project.zip
Schematic_Cat.1 DTU extended version_2022-09-22.pdf
SCH_Cat.1 DTU extended version_2022-09-22.json
62059
speechless
Introduction: qwq
Trolley board
BOM download
PCB_PCB_Speechless Team_2022-09-22.pdf
PCB_PCB_Speechless Team_2022-09-22.json
PCB_Speechless Team_2022-09-22.pcbdoc
Gerber_PCB_Speechless Team.zip
Schematic_Speechless_2022-09-22.pdf
SCH_Speechless Team_2022-09-22.json
Main control board_2022-09-22.schdoc
62060
Very compact CKLink-Tiny[verified]
Introduction: A very compact CKLink debugger, suitable for W800 series chips, supporting virtual serial port
Since the resistors and capacitors are all in 0603 packages, there are some requirements for welding.
CK-LINK Tiny can directly use the firmware of CK-LINK Lite, which can be found in the W801 and W806 groups. The firmware burning method is the same as that of CK-LINK Lite, which can also be found in the group.
![IMG20220124111943.jpg]
BOM download
PCB_PCB_CKLink-Tiny_2022-09-22.pdf
PCB_PCB_CKLink-Tiny_2022-09-22.json
PCB_CKLink-Tiny_2022-09-22.pcbdoc
Gerber_PCB_CKLink-Tiny.zip
Schematic_Very small CKLink-Tiny[verified]_2022-09-22.pdf
SCH_Very small CKLink-Tiny[verified]_2022-09-22.json
62061
electronic
参考设计图片
Search Datasheet?
Forum More
Update:2025-08-08 16:32:13
