蓝猫淘气
NCP4371QC30GEVB: Qualcomm Quick Charge 3.0 Charger Reference Design Evaluation Board
The NCP4371QC30GEVB Evaluation Board is designed to effectively evaluate the NCP4371, which is a USB secondary side fast-charging controller, supporting Qualcomm Quick Charge™ 3.0 (QC 3.0) High Voltage Dedicated Charging Port (HVDCP) Class A and Class B specification. NCP4371 allows for selection of the output voltage of an AC-DC USB adapter based on commands from the Portable Device (PD) being powered. Selecting a higher charging voltage will reduce the charging current for a given power level resulting in reduced IR drops and increased system efficiency. Another advantage of QC3.0 is a decreased battery charging time and a reduced PD system cost thanks to the ability to select an optimum charging voltage. This eliminates the need for costly DC-DC converters within the PD. The USB-bus voltage can be controlled in discreet steps from 3.6V up to 20V. The output current is limited not to exceed maximum allowable power level.
参考设计图片
Search Datasheet?
Forum More
Update:2025-08-09 05:38:33
