xi9FYSmpL
NFC Campus Map
NWU Map NFC
video_20240909_184639.mp4
video_20240908_225206_edit.mp4
NFC_Tools_PRO.apk
PDF_NFC Campus Map.zip
Altium_NFC Campus Map.zip
PADS_NFC Campus Map.zip
BOM_NFC Campus Map.xlsx
92273
ESP32 Internet of Things (IoT) Call for Entries
A multi-channel voltage input + motor driver board is very practical for development, allowing users to obtain commonly used voltages without relying on a DC power supply box. The motor driver board can control the motor's forward and reverse rotation as well as PWM speed regulation.
In the process of redevelopment,
we often need to supply different power voltages to the system, but the commonly used ones are always the same few. Therefore, we often rely heavily on DC power supply boxes. However, owning a power supply box is relatively expensive and inconvenient to carry. So, after learning about PD (Power Distribution Module) triggering, I decided to make a multi-voltage output, compact, convenient, and low-cost power output board.
The semiconductor cooling/heating cup holder I made last time did not achieve forward and reverse rotation due to a mistake in the bootstrap circuit design. So, I made it this time as well. The driver board can also be used to drive motors or other loads. The power supply will be a 12V output from the PD triggering. For
the PD-triggered power output board, I prepared two solutions: one with a 3.3V output and the other with a voltage output only supported by the PD protocol. Adding a step-down circuit would significantly increase the board's size; I wanted a very compact board, similar in size to a USB-to-serial module. I'm using resistor configuration because level configuration requires CFG2 and CFG3 to be around 3.3V, necessitating a step-down circuit to obtain this 3.3V. Therefore, I've included a level configuration interface (not yet verified) on the 3.3V version of the power output board. ( The product was returned. ) It's smaller than I imagined =_= I even added a casing. I had a coupon, so I didn't use it. After testing, 9V, 15V, and 20V all output normally. 5V requires connection to a computer or a charger that doesn't support PD triggering. However, the 12V output becomes 15V. Hardware checks are fine; I suspect the plug doesn't support 12V output. The plug vaguely says 6-20V. But my driver board is 12V powered. There's no way around it; I still have to use a power supply box. The motor driver board description includes 12V to 3.3V (for microcontrollers), and an H-bridge circuit (to achieve positive...). The circuit includes a current sampling circuit, a main control chip, an OLED interface, and three LEDs and three buttons. I reserved an interface for testing the EG2312. Last time, when testing with DuPont wires, I accidentally touched a nearby pin and broke the chip. This time, I carefully verified that after powering on, the EG2312 tested normally via the header pins. This chip has a built-in protection mechanism and will not experience a short circuit due to simultaneous conduction of the upper and lower terminals. Later, I used a 50% duty cycle to control the upper (positive) MOSFET, and the phenomenon was normal. However, when I controlled the lower (negative) terminal, the HO output immediately cut off after a short while. The reason is unknown, but I guess it's due to timing mismatch, which I interpreted as a short circuit due to simultaneous conduction of the upper and lower terminals, causing it to stop working. For the initial load test, I used a thermoelectric cooler with a thermometer for a more intuitive digital temperature display. Here, I only gave it a 50% duty cycle, meaning the cooler operates at 6V. Full operation would yield better results. Current sampling:........................ Thermistor feedback:..........................................................
PDF_ESP32 Internet of Things Call for Entries.zip
Altium_ESP32 IoT Call for Entries.zip
PADS_ESP32 Internet of Things (IoT) Call for Entries.zip
BOM_ESP32 Internet of Things (IoT) Call for Submissions.xlsx
92274
ESP32 Simple Cyclist
Create a simple code table using ESP32.
I. Project Description
This is a simple GPS cycling computer. I admired the cycling computers made by experts, but felt they were too difficult to implement. Seeing LCSC's ESP32 design competition, I took this opportunity to create this simple cycling computer. As its name suggests, it's a simple GPS cycling computer. Initially, I wanted to design all functions as modular systems, connecting all modules via adapter boards. However, in practice, I found that modular systems would result in a very large computer (and the current one is already quite large). Ultimately, I modularized the main controller, GPS, and display screen. The remaining components, such as the accelerometer, charging/discharging circuit, and SD card, were still designed on the main board.
II. Hardware Components
The hardware consists of four main parts: an ESP32C3 development board (without a serial port), a 4G+GPS module purchased online, a TFT module made using LCSC's open-source project, and an adapter PCB. The adapter PCB houses the charging/discharging circuit, MPU6500 circuit, SD card circuit, and a rotary encoder.
Since most components are modular, the circuitry on the main board is greatly simplified. The integrated charging/discharging circuit, MPU6500 circuit, SD card circuit, and a rotary encoder were all designed according to the manual or referenced from other open-source projects, with basically no changes. The reason for choosing the integrated charging/discharging circuit instead of the 4056 chips I already had is that the 4G+GPS module I bought requires a 5V power supply, and I didn't want to create a separate boost circuit, so I chose the IP5306 integrated charging/discharging chip.
I actually made two versions (actually three, the third version was improved but not printed). After making the first version, I found that the wiring of the TFT screen and the reserved wiring for the screen were reversed. After revising the second version, I found that the screen was intermittently malfunctioning. After two days of troubleshooting, I found that it was caused by placing the SCL under the boost inductor, which caused signal turbulence. This was temporarily solved by using a jumper wire. To explain this problem, on the one hand, I didn't pay attention when revising the second version; in the first version, I specifically avoided the inductor. On the other hand, I thought that since it's a closed inductor, it shouldn't have much impact, but in reality, it had a significant impact. The PCB routing in the final version has been adjusted.
Another issue is the MPU6500. I bought three chips from three different stores on Taobao, soldered them onto three boards, and after some tweaking, they still weren't generating data. Finally, just before the project deadline, one of them started generating data. I don't know if it was due to poor soldering skills or if the chips themselves were faulty.
Thirdly, the software part
uses the tinyGPS and MPU6050 libraries from Arduino to implement the function of controlling the 4G+GPS module to receive GPS data and read angles from the MPU6500 via the main controller. This is a relatively basic and core function. I will continue to enrich and optimize the software later, adding SD card, button, and MQTT functionality.
Demo video_2024913105019.mp4
PDF_ESP32 Simple Code Table.zip
Altium_ESP32 Simple Code Table.zip
PADS_ESP32 Simple Code Table.zip
BOM_ESP32 Simple Code Table.xlsx
92275
ESP32 Homeassistant - Colorful Lights
This is my first open-source project using ESP32 to create Home Assistant
. Please feel free to correct any errors. Thank you.
Project Introduction
: This section provides a basic description of the project. Example:
This project is a HomeAssistant remote LED light system based on the ESP32 module. It features remote network access, remote control, and audio rhythm display.
Project Functions
: 1. ESP8266 Functions: Remotely control the external power supply, control the ESP32 module's on/off state, and determine whether it enters working mode;
2. Uses the ESP32 as the main control module to control the LED strip's operating status, including audio acquisition. The ESP32 controls different colors such as RGB;
3. The ESP8266 uses the ESPHome function to connect to HomeAssistant.
Project Parameters
: DC-DC Power Supply Chip: SY8205FCC
Chip; Input Voltage: 4.5-30V;
Output Voltage: 5A continuous, 6A peak load current capability;
Reference Voltage FB: 1.5% 0.6V; Reference
Principle Analysis (Hardware Description)
: This section can be used to fill in the project's design principles, breaking down and analyzing the design principles. Example:
This project consists of the following parts: power supply section, USB download circuit, ESP8266 main control section, ESP32 main control section, RGB output interface section, and audio acquisition section. This project is mainly based on Home Assistant remote control to achieve flashing of home ambient lights.
Example Figure 1 -- Power Supply Circuit:
1. Using a DC-DC power supply chip to achieve a high current load, it can achieve the lighting effect of hundreds of LED beads in the application.
2. When there are too many LED beads in the subsequent stage, remember to open the PCB and perform tin plating to ensure that the PCB copper can meet the current required by the colored lights.
1. Check the SW4 toggle switch; its application in the ESP32 module enables USB serial port data download. 1. When no external power is connected, the switch is in the "up" position. The USB provides power to the DC-DC chip, enabling the CH343P to be correctly powered and download firmware (the ESP8266 needs to be programmed first, ensuring the ESP32_EN pin is high and the ESP32 module is powered on).
2. After the ESP32 module firmware download is complete, slide SW4 down to ensure the ESP32 module operates normally
. 3. For this quick demonstration, the ESP8266 module program is written using Arduino and runs normally.
Precautions:
1. First, program the ESP8266: Press the download button, and during programming, press and release the reset button to start the download.
2. When downloading the ESP32 firmware, some browsers may display "Initialization failed." Please download and update the CH343 driver firmware from the Qinheng official website, or use a different browser such as 360 Browser or Firefox.
3. After successfully downloading the firmware, if clicking "Next" has no effect or the page refreshes, check if the toggle switch is in the "off" position to ensure the CH343P is no longer working. Otherwise, the ESP32-IO0 pin will be low and will not work;
4. This sample requires some prior knowledge of Home Assistant;
[Image of the actual product]
Video demonstration.mp4
ESP32-Colored Lights.zip
PDF_ESP32-Homeassistant-Colorful Lights.zip
Altium_ESP32-Homeassistant-Colored Lights.zip
PADS_ESP32-Homeassistant-Colored Lights.zip
BOM_ESP32-Homeassistant-Colorful Lights.xlsx
92276
Based on ESP32 IoT smart home
IoT smart home monitoring system developed based on Espressif ESP32 S3 module
Project Overview
This project is an IoT smart home monitoring system designed and developed based on Espressif's ESP32 series modules. Espressif's ESP32 is powerful because it integrates WiFi functionality as an MCU, enabling some small systems to access the internet through a single microcontroller. Using an STM32 or other MCU would require external expansion with other internet-enabled modules. Furthermore, the ESP32's performance is superior to the STM32. Therefore, Espressif's ESP32 series has unique advantages in IoT project design.
This system uses sensors for temperature, humidity, and illuminance to detect environmental information and controls drive devices to adjust accordingly, responding to environmental changes. A WeChat mini-program has been developed as the host computer, allowing remote viewing of sensor data and control of device on/off status for fans, windows, etc.
Project Functions
This design is a smart home monitoring system based on the ESP32; it features temperature, humidity, and illuminance sensors and three independent buttons for fan on/off, window on/off, and automatic detection on/off. When automatic detection is enabled, the fan (or window) will automatically turn on or off when the temperature, humidity, or illuminance exceeds a threshold range; when automatic detection is disabled, the switch can be manually controlled. The system features a WeChat mini-program, allowing remote viewing and modification of sensor values ​​and system on/off status.
Project Parameters:
This design utilizes a 0.96-inch OLED display, showing the on/off status at the top and temperature, humidity, and illuminance sensor values ​​below.
A fully digital DHT11 temperature and humidity sensor is selected, offering a wide temperature measurement range suitable for general needs.
A GL5516 photoresistor is chosen as the illuminance sensor, offering low cost and ease of implementation and portability.
Principle Analysis (Hardware Description) :
The hardware of this project consists of the following components: power supply circuit, serial port circuit, main control circuit, sensor circuit, driver circuit, and human-machine interface circuit.
1. Power Supply Circuit
: A TYPE-C-16P interface is used as the power supply interface. The corresponding USB data pin is connected to the CH340C (to convert the USB signal to a TTL serial port signal) for downloading and debugging. The USB power supply is connected to the +5V network via R27 (actually 0R or directly shorted). Disconnecting R27 allows for external power supply to the board, enabling observation of the board's operating current and power consumption. After debugging, the board can be directly powered via USB. 1. +5V is converted to 3.3V via AMS1117 to power the ESP32 and other components.
2. The serial port circuit
uses automatic downloading, eliminating the need to press the EN and BOOT keys to program.
3. The main control circuit
is connected according to the Espressif official manual and has been verified to work stably.
4. The
DHT11 sensor circuit communicates with the ESP32 via a single bus. A pull-up resistor needs to be added to the DATA pin to improve its driving capability.
The photoresistor uses a voltage divider to read the analog signal from the ESP32 ADC and converts it to illuminance (Lux) using a lookup table.
5. The drive circuit
uses a transistor drive circuit to control the fan switch. Note that D2 is a freewheeling diode; it needs to be soldered to prevent damage to the circuit from the reverse electromotive force caused by the fan's inductive characteristics during startup and shutdown. The power supply status can be checked with an oscilloscope; soldering D2 significantly improves power spikes.
6.
The three buttons in the human-machine interface circuit are connected to the ESP32 pins via pull-up resistors to ensure the pin level is high when the button is reset and low when pressed.
The OLED display is connected via an I2C bus as shown in the diagram.
The software code
is developed based on Arduino IDE 2.0.4 + ESP Board Pack 3.0.0. Arduino's powerful library resources can effectively reduce development workload and improve development efficiency. However, Espressif's official ESP-IDF is more helpful for understanding the underlying resources of ESP32 and FreeRTOS development, and further development will be carried out later. See the attached project
notes.
In the project's physical diagram, the OLED display is reversed; it should actually be pasted on the front of the board. This was mainly due to the initial PCB layout being drawn incorrectly, which has been corrected. However, due to time constraints, only the first version of the hardware could be demonstrated.
[Physical diagram]
New video1.mp4
ESP32IoTHome.zip
PDF_ESP32-based IoT Smart Home.zip
Altium_ESP32-based IoT Smart Home.zip
PADS_ESP32-based IoT Smart Home.zip
BOM_Based on ESP32 IoT Smart Home.xlsx
92277
ESP32-based WIFI progressive sleep alarm clock system
The progressive alarm clock system based on the ESP32 microcontroller is an innovative product that integrates smart home technology, aiming to provide users with a more comfortable and convenient wake-up experience.
Hardware Design: Based on the high-performance ESP32 microcontroller, design and build a complete hardware system. This system will include an OLED display for clearly showing time, date, and weather information; a soft-light LED array to simulate sunrise light and help users gradually wake up; an audio decoder and speaker to play soft music to assist in waking the user; buttons for function switching, time adjustment, etc.; and a battery to ensure the system's portability and independence.
Software Design: Develop embedded software using VS Code and the Arduino environment to implement functions such as time synchronization, weather acquisition, and gradual wake-up. The software will adopt a modular design to improve maintainability and scalability. A user interface and interactive functions will also be developed to allow users to easily personalize and adjust settings. Currently, all functions work perfectly. However, when soldering, remember to reverse the Source and Ground wires of the two MOSFETs controlling the LEDs; otherwise, the LEDs will remain constantly lit and uncontrolled by the microcontroller. The image
above shows the LED before the wires are reversed, meaning the LEDs are constantly lit and uncontrolled by the program. The image below shows the LED after the wires are reversed, meaning
the LEDs can be controlled by the microcontroller for switching on/off and brightness, and other functions also work perfectly.
176147cebc2d859d880e5738e466e6db.mp4
ArduinoProject.zip
PDF_ESP32-based WIFI progressive sleep alarm clock system.zip
Altium_ESP32-based WIFI progressive sleep alarm clock system.zip
PADS_ESP32-based WIFI progressive sleep alarm clock system.zip
BOM_ESP32-based WIFI progressive sleep alarm clock system.xlsx
92278
ESP32 camera
The project will use the ESP32-PICO-D4 as the core processing unit, in conjunction with the OV7670 camera module to capture images and display them on a TFT screen.
I. System Architecture
Hardware:
ESP32-PICO-D4: Responsible for image data processing, compression, and Wi-Fi communication.
OV7670 Camera Module: Responsible for capturing images from the environment.
Power Module: Provides a stable 3.3V power supply.
Software:
ESP32 Firmware: Developed using VSCode + PlatformIO, mainly responsible for initializing the camera, acquiring image data, compressing images, and displaying them on the TFT screen (web interface not yet implemented QAQ). The code isn't very good; I'll post it in the comments later.
Physical Image
II. Workflow
Image Acquisition: The OV7670 camera module captures image data and transmits it to the ESP32-PICO-D4 via a data interface.
Data Processing: The ESP32 preprocesses the image data, compressing it into a format suitable for transmission.
Data Transmission: The ESP32 sends the image data to the TFT display screen via SPI.
Image Display: The display screen receives the image data and displays it in real time.
III. Project Extension
Storage Function (To be implemented): Image data can be saved to an SD card or uploaded to cloud storage.
Motion Detection (To be implemented): Utilizes image processing algorithms to detect moving objects in the scene and trigger alarms or notifications.
IV. Project Applications
: Home Security Monitoring: Deploy cameras in the home and view real-time footage via mobile phone.
Unattended Monitoring: Remote monitoring in unoccupied areas, suitable for construction sites, warehouses, etc.
Outdoor Photography: Small, but generates a lot of heat (approximately).
camera.mp4
PDF_ESP32 camera.zip
Altium_ESP32 camera.zip
PADS_ESP32 camera.zip
BOM_ESP32 camera.xlsx
92279
ESP32 C3
Simplified version of LCSC - Practical Approach
Open source address: https://gitee.com/st7_1a/esp32-c3.git
Function introduction: (Due to shooting issues, the screen image may not be very good)
Main interface: After powering on, connect to the mobile hotspot. After a few seconds, the real-time time will be displayed in the upper left corner.
Interface 2: Displays real-time weather conditions. This part is referenced from LCSC's Practical App.
It will reconnect to the mobile hotspot every once in a while.
Interface 3: Functional interface
1. The color palette in the upper left corner controls the RGB lights under the board. Select any color, then long-press the blank part in the middle of the color palette to jump to the color palette from dark to light... and so on. After trying a few times, it will jump back to the initial color palette. The avocado switch controls the RGB lights to turn on and off.
2. The button in the middle on the right controls the buzzer. There are two modes: a short press makes a sound, "the middle Buzzer will change to Short".
        A long press makes intermittent sounds, stopping after 5 seconds, "the middle Buzzer will change to Long".
3. The two sliders in the lower right corner control the screen brightness and volume respectively.
4. The curve in the lower left corner displays the battery level in real time.
The board also has a gyroscope and a temperature and humidity sensor, the same model as those on the LCSC Practical Edition, which are already soldered and can be used directly with the official code.
video.mp4
PDF_ESP32 C3.zip
Altium_ESP32 C3.zip
PADS_ESP32 C3.zip
BOM_ESP32 C3.xlsx
92280
ESP32-WLED Music Rhythm Light Strip
esp32+inmp441, flashed with wled software, integrated with Home Assistant to enable automatic switching of music rhythm and ambient lighting.
This project is based on ESP32 and INMP441, flashed with the WLD program, and integrated with Home Assistant to achieve automatic switching between music rhythm and ambient lighting.
Project Functionality:
The Blue Night speaker is integrated with Home Assistant. When music is played through Home Assistant, the music rhythm effect is automatically switched, and the WLD music rhythm function is enabled. When no music is playing, the ambient lighting effect is switched, and the WLD music rhythm function is automatically disabled.
Project Parameters:
This design uses the INMP441 module for easy soldering;
a 4-pin interface for easy connection to the WS28xx series;
one spare interface is reserved;
the LED strip has an independent power supply
interface. 3D shell
programming and configuration are available
at https://install.wled.me/
. Select the Audioreactive version
, connect to WiFi, enter the ESP32 IP address, open the WLEED interface
, find MQTT under Config->Sync Interfaces, open and configure the HA MQTT.
Restore my presents (wled_presets_WLED-CL.json) or create
a new automation for Bluetooth speaker volume and lighting control in HA. The attached file contains code; modify it to match your corresponding entity and WLEED MQTT theme.
Important Notes:
Only one of the independent power supply and signal line VCC can be connected. When programming
with M2*10 screws,
if only the serial port is connected and not the power supply, D2 needs to be shorted; otherwise, the voltage will be insufficient.
WeChat_20240910082720.mp4
Bluetooth speaker volume & light control.yaml
PDF_ESP32-WLED Music Rhythm Light Strip.zip
Altium_ESP32-WLED Music Rhythm Light Strip.zip
PADS_ESP32-WLED Music Rhythm Light Strip.zip
BOM_ESP32-WLED Music Rhythm Light Strip.xlsx
92281
Simple voice-activated e-ink clock with one-touch countdown and alarm functions
This is a pure e-ink clock based on the ESP32 chip. Its basic functions include displaying date and time, alarm clock, and countdown timer. It features a low-power design, button settings, online Wi-Fi time updates, a built-in web page for clock and time synchronization, and offline use without Wi-Fi.
This is a pure e-ink clock based on the ESP32 chip, featuring basic alarm clock, one-button countdown, and voice-activated alarm settings. It boasts a low-power design, allows for online Wi-Fi time updates, and has a built-in web page for clock and time synchronization. It can
also be used offline without Wi-Fi. Many open-source e-ink clocks offer a wide range of features, but my requirements are simple: a basic clock display, alarm, and timer functions, while also considering power consumption, offline usability, and easy time setting.
Therefore, I designed this clock using the ESP32-WROOM-32D as the main controller. The ESP32 has abundant available I/O, and the peripheral circuitry only includes automatic downloading, lithium battery charging, an 8025 clock chip, a buzzer, e-ink driver, and button circuitry. The circuit is relatively simple and easy to replicate. The cost is also low; the main components are the ESP32 module and the e-ink screen. The 8025 clock chip is inexpensive and cost-effective. Without the ASRPRO offline voice module, the total cost should be below 30 yuan.
Low-power design: Upon power-on and connecting to Wi-Fi to update the time, the ESP32 enters Deepsleep mode. The 8025 clock chip generates an interrupt every minute to wake the ESP32 and update the e-ink display. After the update is complete, it immediately enters Deepsleep mode again. After pressing the settings button, wait only 2 minutes before automatically entering Deepsleep mode. Connecting to the built-in webpage to set the time and alarm must be completed within 2 minutes. Power is only supplied to the offline voice module after pressing the voice button. After 15 seconds of power supply, it automatically shuts off and enters Deepsleep mode. Voice commands must be spoken 3 seconds after pressing the button and completed within 15 seconds!
In testing, the time was updated via Wi-Fi once a week or once a month, and the time display remained very accurate. Therefore, the power consumption is mainly limited to the 8025 clock chip and the e-ink display. The 1000mAh battery has been tested for a month and still has power!
For a demonstration video, please visit Bilibili: https://www.bilibili.com/video/BV1664nenEhg
Known issue:
After pressing the voice button and powering on the offline voice module, it takes 2-3 seconds for the voice command to be recognized. This is likely due to a startup and loading time for the voice module.
After connecting via the clock's access point (AP), the webpage updates the time from 2024, but the clock displays 2042. What kind of bug is this?
Implemented features include:
1. Basic time display, alarm clock, and countdown reminder;
2. Network NTP time update function;
3. When there is no Wi-Fi, connecting to the clock AP and using the built-in webpage to synchronize time;
4. Button-based alarm and countdown
time setting function; 5. Clock's built-in webpage for setting alarm and countdown time
; 6. Selectable network time update frequency or no network time update function;
7. One-click countdown start function;
8. Offline voice setting of alarm and countdown time function; (optional function)
The five buttons' layout and functions:
Pressing the set button will cycle through five configurable items: alarm hour, minute, alarm on/off, alarm mode, and countdown time. Pressing the increase and decrease buttons adjusts the value of the selected item. When the clock is in setup mode, it will simultaneously turn on its Wi-Fi and connect to the designated Wi-Fi network. Once connected, the clock's IP address will be displayed in the lower left corner. If not connected to Wi-Fi, the clock will create a hotspot named "myclock"
. After connecting to the "myclock" hotspot, access the settings page at 192.168.4.1. You can then access the following three built-in clock settings pages: Wi-Fi settings; clock, alarm, and countdown settings; and time synchronization.
One-click countdown function:
Alarm and countdown times can also be set offline via voice. For a demonstration, please see the demo video on Bilibili.
The voice function uses the ASRPRO offline voice module, and the programming software is Tianwen Block .
The ESP32 program uses the Arduino language, and the development tools are VSCode + Platformio.
The ESP32 source code, ASRPRO source code, and compiled firmware are all uploaded as attachments. The ASRPRO module firmware can be uploaded using Qiying Tailun's programming tool!
EDP_Test2.zip
esp32bin.zip
asrproCode.zip
asrprobin.zip
PDF_Simple Voice E-ink Clock with One-Touch Countdown and Alarm Functions.zip
Altium - A simple voice-activated e-ink clock with one-touch countdown and alarm functions. (zip)
PADS - A simple voice-activated e-ink clock with one-touch countdown and alarm functions. zip
BOM_Simple Voice E-ink Clock with One-Touch Countdown and Alarm Functions.xlsx
92282
electronic
参考设计图片
Search Datasheet?
Forum More
Update:2026-03-28 01:13:48
  • How is the precise measurement of the Wheatstone bridge demonstrated?
  • SATA Layers
  • TM4C123GPTM's PWM mode generates square waves
  • 【Play with C2000 Launchpad】 Four TMS320F2802x Peripheral Guide
  • Questions about CC3200
  • Control of permanent magnet brushless DC BLDM
