Z6AjBycje
MSP432 Electronic Racing Car Expansion Board
It is particularly important to note that the JY901S cannot be grounded. Grounding at the magnetometer chip area is also prohibited, as it will cause electromagnetic interference to the magnetometer, leading to inaccurate Z-axis angles. For detailed information, please refer to: FAQs (yuque.com). This MSP432 expansion board includes the following resources: 1. Serial port 3 and 4 pins are exposed. Note that jumpers for serial ports 1 and 2 need to be removed. 2. Servo expansion port. 3. RGB_LED expansion port. 4. Separate power supply for the microcontroller (to prevent damage to the MSP432). 5. TB6612 motor driver chip pins (can be directly installed using a connector, convenient and secure). 6. JY901S expansion port: Again, it is particularly important to note that the JY901S cannot be grounded. Grounding at the magnetometer chip area is also prohibited, as it will cause electromagnetic interference to the magnetometer, leading to inaccurate Z-axis angles. For detailed information, please see (P2.3): https://wit-motion.yuque.com/wumwnr/docs/mt1da8kcsy7iie8h7, Buzzer 8, Bluetooth 9, OLED
参考设计图片
Search Datasheet?
Forum More
Update:2026-03-28 00:30:58
  • HDMI interface to LVDS display
  • Amplifier circuit analysis method problems
  • I'm posting a note I just wrote, it's still hot.
  • iSL59530
  • Problems with verilog drivers
  • Has anyone made a driver for the ov7255 camera? Mine doesn't produce an image....
