H7DgFMLrS
Yangzhou University Slender West Lake Campus Map NFC Card
The description is nothing special; it's all borrowed from other community members. The map was drawn bit by bit from Gaode Maps. My aesthetic sense isn't great, but I've done my best to make it look like this. You can customize it yourself.
For the chip, you can use a COB213 chip or a CUID/UID, but it might not have campus card functionality. You can extract the chip from your campus card; you can search online for tutorials.
PDF_Yangzhou University Slender West Lake Campus Map NFC Card.zip
Altium_Yangzhou University Slender West Lake Campus Map NFC Card.zip
BOM_Yangzhou University Slender West Lake Campus Map NFC Card.xlsx
94758
4G power supply board
4G Internet module
4.6 The 4G Cat.1bis Internet access module adopts the ESP-IoT-Bridge solution. The ESP-IoT-Bridge solution is primarily designed for connectivity and communication between various network interfaces in IoT application scenarios, such as SPI, SDIO, USB, Wi-Fi, and Ethernet. In this solution, the Bridge device can provide internet access for other devices and also function as an independent device connecting to a remote server. The ESP-IoT-Bridge wired network card device can connect to the network by inserting an Ethernet cable into the router's LAN port and connect to a PC or MCU through multiple network interfaces (USB/SDIO/SPI) to provide internet access capabilities. One end of the USB cable connects to GPIO19/20 of the ESP32-S2/ESP32-S3, and the other end connects to the MCU.
4G Cat.1bis Internet Access Module Code (1).zip
PDF_4G Power Supply Board.zip
Altium_4G power supply board.zip
PADS_4G Power Supply Board.zip
BOM_4G Power Supply Board.xlsx
94760
electronic
参考设计图片
Search Datasheet?
Forum More
Update:2026-03-29 04:56:15
