wELGJ
Cherry 1800 -375-V02
The onboard charging module and overcharge/overdischarge protection module are
included
. The slide switch is located below the spacebar and requires removing the keycap to turn it on. It
has one external switch slot and uses a 1.25mm pitch female connector. An 8mm self-locking switch can be used. After soldering 1.25mm pitch wire, it can be fixed to the casing.
The schematic is imported from the standard version; the silkscreen position is slightly offset. Please adjust it slightly when ordering.
Taobao link:
https://item.taobao.com/item.htm?ft=t&id=650364556086&spm=a21dvs.23580594.0.0.1d293d0d5wbe4N
参考设计图片
Search Datasheet?
Forum More
Update:2026-03-27 01:39:10
