2OEn3baMo
STC8H8K64U Minimum Development Board
On the STC8H8K64U minimum development board for Mac, the programming
was tested by entering the command
: `shell
stc8prog -p /dev/cu.usbserial-14610 -e -f . / build/Debug /LearnSTC89C52RC.hex`
. When the screen displays " Witing for MCU, please cycle power: ", press the power button to start programming . (Images of the power button are included . )
copy_CA58AA55-960E-4E09-846B-93BCEFCFEDB4.MOV
STC8H8K Minimum Development Board Casing. 3mf
STC8H8K Minimum Development Board Shell - Top. 3mf
PDF_STC8H8K64U Minimum Development Board.zip
Altium_STC8H8K64U Minimum Development Board.zip
PADS_STC8H8K64U Minimum Development Board.zip
BOM_STC8H8K64U Minimum Development Board.xlsx
95869
Accessories - Sickle
These are ordinary handicrafts, accessories for another project. When I made them, I forgot to cut a window behind the flower and covered it with oil so it wasn't very translucent. I'm too lazy to change it, so you can modify it yourself if you want. As for the circuitry, you can figure it out yourself. The ceramic filaments are generally too short, and the packages in the library that are drawn according to the specified lengths are quite difficult to solder.
This sickle design is for personal reference; please cite the source if using it.
Gerber file is attached .
sickle.zip
PDF_Accessories - Sickle.zip
Altium Accessories - Sickle.zip
PADS Accessories - Sickle.zip
BOM_Accessories - Sickle.xlsx
95871
STM32 Multi-channel LED Constant Current Driver
LED lighting controller placed in the dormitory
PDF_stm32 Multichannel LED Constant Current Driver.zip
Altium_stm32 multi-channel LED constant current driver.zip
PADS_stm32 Multi-channel LED Constant Current Driver.zip
BOM_stm32 Multi-channel LED Constant Current Driver.xlsx
95873
STM32F103C8T6 Minimum System Learning
32-bit minimum system + MPU6050 + screen
Configure the minimum system board according to the manual, and then add peripheral components. This system is used for counting steps, displaying time, and obtaining the current attitude angle.
PDF_stm32f103c8t6 Minimal System Learning.zip
Altium_stm32f103c8t6 Minimal System Learning.zip
PADS_stm32f103c8t6 Minimal System Learning.zip
BOM_stm32f103c8t6 Minimal System Learning.xlsx
95874
CH32V003F4U6 Nano Board
A Qinheng CH32V003 mini development board.
It was done rather hastily, referencing this project (https://oshwhub.com/maxgustav/ch32v003f4). I feel the pin header order could be optimized.
It uses the CH32V003F4U6, QFN-20 (3x3) package, and has full CH32V003 functionality. It has an onboard 24MHz passive crystal oscillator. Functionality has been verified.
The silkscreen printing on the prototype board in the image had a slight issue, but it has been corrected in the project files and should be OK now.
PDF_CH32V003F4U6 Nano Board.zip
Altium_CH32V003F4U6 Nano Board.zip
PADS_CH32V003F4U6 Nano Board.zip
BOM_CH32V003F4U6 Nano Board.xlsx
95875
[Liangshan Sect] Intelligent Car
This project is a smart car designed based on the LCSC-Liangshanpai development board.
I. Car Functions
: Left and right light indicators; buzzer prompts; button control function; ADC voltage acquisition; four-channel infrared tracking function; HC-SR04 ultrasonic obstacle avoidance function; HC-05 Bluetooth module communication;
II. Car Circuit Design
: 1. Power input module;
2. Button indicator lights; vehicle lights;
3. Button module;
4. Buzzer module;
5. ADC voltage acquisition circuit;
6. N20 motor drive circuit;
7. Four-channel tracking circuit;
8. HC-SR04 ultrasonic module;
9. HC-05 Bluetooth module;
Car video.mp4
Smart Car.zip
PDF_【Liangshan School】Smart Car.zip
Altium_【Liangshan Sect】Smart Car.zip
PADS_【Liangshanpai】Smart Car.zip
BOM_【Liangshan Sect】Intelligent Car.xlsx
95878
C64 PLA replacement
Used for repairing and replacing PLA chip 906114-01 in Commodore 64 computers.
The Commodore 64, released by Commodore in 1982, sold over 12 million units throughout its lifecycle, holding the Guinness World Record for "Best-Selling Single Desktop Computer Model." The PLA chip is responsible for memory address decoding. A malfunction manifests as a black screen upon startup. Because the PLA chip (906114-01) has been discontinued for many years, finding an original replacement is difficult. Therefore, a GAL chip can be used for simulation. This project is a re-drawn version of the PLA20V8 project. https://www.freepascal.org/~daniel/c64pla/
PDF_C64 PLA Replacement.zip
Altium_C64 PLA Replacement.zip
PADS_C64 PLA Replacement.zip
Replace .xlsx with BOM_C64 PLA.
95880
USB2514B-USB Hub Expansion Dock
USB2514B-AEZC-TR Dock
This high-speed 2.0 expansion dock uses
the MICROCHIP USB2514B-AEZC-TR high-speed and stable hub controller.
While the chip itself is relatively expensive, it's cheaper on Taobao, but refurbished units are common. I bought three, all refurbished, and one failed. It's worth a gamble; this design uses a refurbished unit.
The
circuit doesn't require programming; it's ready to use after soldering.
The speed of copying files via USB is shown in the image below. Playing internal videos from a Type-C SSD is also very stable and smooth.
Be aware of cold solder joints, as refurbished units are prone to this.
If the computer doesn't respond or displays a "USB device request failed" message, it's a soldering issue.
The CH340 port is recognized successfully, but a USB flash drive fails to display the "USB device request failed" message—this may be a chip problem .
This project uses a 0402 package.
PDF_USB2514B-USB Hub Expansion Dock.zip
Altium_USB2514B-USB Hub Expansion Dock.zip
PADS_USB2514B-USB Hub Expansion Dock.zip
BOM_USB2514B-USB Hub Expansion Dock.xlsx
95881
electronic
参考设计图片
Search Datasheet?
Forum More
Update:2026-03-27 21:56:41
