DongshanPI-D1s all pins support CKlink
PDF_DshanLiteRV_FullDIYBoard_V1.zip
Altium_DshanLiteRV_FullDIYBoard_V1.zip
PADS_DshanLiteRV_FullDIYBoard_V1.zip
BOM_DshanLiteRV_FullDIYBoard_V1.xlsx
96775
Motor drive based on EG5620
Small motor driver based on EG5620 gate drive module, intelligent vehicle/general DC brushed driver
⚠️Note that
this project was designed using KiCad, so there is no unconditional free PCB fabrication without lceda. The schematic preview is at the bottom, please take note.
If you want to fabricate a PCB, please use Gerber below. The PCB in lceda is imported and is for preview only. The BOM is also below. Please do not use the automatically exported version.
This project was first released on Hardcore Innovation Community. You can go to Hardcore Innovation Community to support me
. I. Product Introduction
This is a high-power, high-efficiency dual-channel motor driver designed and manufactured based on the domestic EG5620 gate driver and 5X6 packaged NMOS (such as SM4503/CSD18540, etc.). It can drive most common DC motors. One motor can be controlled using two PWMs.
II. Application Scenarios
: Prototype development for products such as smart cars and drones;
directly applicable to various competitions with high requirements for motor drive power and efficiency;
III. Product Overview:
This product provides a dual-channel motor drive board based on the EG5620 motor drive controller for electronics enthusiasts and prototype verification engineers. It features:
dual EG5620 H-bridges with 5x6 MOSFETs, high power, low internal resistance, and high efficiency;
single-sided components, with a main body size of only 5.1x3.7cm;
two PWM channels control the forward and reverse rotation and speed adjustment of one motor;
an enable button switch can be used to shut down the drive and prevent it from flying off course;
IV. Product Parameters
: Interface: Power supply uses blue KF301 terminals; logic interface uses a 2.54mm standard interface; speed can be controlled by connecting a PWM signal;
operating voltage: 5V-25V;
production cost: 15-25 RMB (using SM4503/CSD18540);
PCB Parameters: 5.1x3.7cm, two-layer board design, components placed on one side, interfaces on the front.
V. Instructions for Use :
Power supply 5V-25V (2s-6s recommended) .
One motor uses two PWM controls;
see 3D diagram for connection details
. VI. Remarks:
This is a pure hardware project; no code library is provided, and the module does not contain programmable devices.
A 3.3V-5V level microcontroller is recommended.
MOSFET Selection Recommendation: SM4503 is used in the video test; CSD18540 can also be used.
VII. Test Video
ibom_motor_driver_1.6_2023-11-28.html
gerber_bom_pos_motor_driver_V1.6.zip
PCB_motor_driver.7z
output2.mp4
output1.mp4
PDF_Engine Driver Based on EG5620.zip
Altium_Engine Driver Based on EG5620.zip
PADS_Eng5620-based motor driver.zip
BOM_Motor Driver Based on EG5620.xlsx
96776
miniwiggler-new
DAP Miniwiggler Infineon Tricore series microcontroller downloader/debugger
⚠️Note that
this project uses KiCad for design, so there is no unconditional free PCB fabrication without lceda. The schematic preview is at the bottom, please take note.
This project was first released on Hardcore Innovation Community. You can go to Hardcore Innovation Community to support me.
This project is based on the FT2232HL chip and uses miniWiggler for downloading and debugging Infineon series microcontrollers.
The miniWiggler emulator is a high-performance, low-cost, and high-efficiency debugging tool;
miniWiggler is currently the mainstream development tool for Infineon microcontrollers.
miniWiggler is suitable for use in Infineon's intelligent vehicle related groups .
This emulator uses the FT2232HL chip.
The emulator supports AURIX Development Studio/Memtools;
: Main control chip: FT2232HL;
Supports USB 2.0 Type-C high-speed communication interface;
Supports USB hot-swapping and DAP hot-swapping;
Only supports 10-pin DAP interface;
Has a serial port;
Two-layer PCB design, approximate size: 69mm*24mm;
V. Instructions for Use:
Connect the Type-C data cable to the computer, and connect the DAP pins to the development board as needed for program downloading.
VI. Notes:
This programmer requires driver and firmware downloads; see attachments for details.
VII. Schematic Diagram/Test Video
miniwiggler_firmware burning guide.zip
output.mp4
gerber_bom_pos_miniwiggler_new_Alpha.zip
ibom_miniwiggler_new_Alpha_2023-11-21.html
PCB_miniwiggler_new.7z
SCH_miniwiggler_new.pdf
PDF_miniwiggler-new.zip
Altium_miniwiggler-new.zip
PADS_miniwiggler-new.zip
BOM_miniwiggler-new.xlsx
96777
Dongshan Nezha STU All-Pin DIY Board
This is a full-pin DIY motherboard, which brings out all unused pins of the smallest motherboard to the baseboard headers
and provides all hardware design information. You can design and manufacture your own using JLCPCB
. Suitable for: Students with strong hands-on skills and those who enjoy DIY projects.
This is a full-pin DIY motherboard, which brings out all unused pins of the smallest motherboard to the baseboard headers and provides all hardware design information. You can design and manufacture your own using JLCPCB. Suitable for: Students with strong hands-on skills and those who enjoy DIY projects.
PDF_Dongshan Nezha STU Full Pin DIY Board.zip
Altium_Dongshan Nezha STU Full Pin DIY Board.zip
PADS_Dongshan Nezha STU All-Pin DIY Board.zip
BOM_Dongshan Nezha STU Full Pin DIY Board.xlsx
96778
electronic
