5442 views|2 replies
280
Posts
Resources
The OP
The peak of the switching power supply [attached picture], is this considered high? [Copy link]
I used a switching power supply in my project, and I felt that the burrs were relatively large during use. Some power modules would cause the digital circuit to malfunction (the digital module was normal after changing the power module or DC), so I would like to ask the experts, is the burr of my switching power supply large? The output is 5V DC. Is there any good way to suppress it?
This post is from Power technology
Latest reply
The ripple is too large. Change the absorption circuit of the switch tube and the rectifier tube, and then the feedback. There is a chance.  Details Published on 2010-6-1 09:12
3832
Posts
Resources
It looks very high. If it is everywhere, you should check whether the probe grounding is not clean enough. If the switching speed can be reduced, the noise can be reduced. A better PCB can also reduce the noise.
228
Posts
3667
Resources
Guess Your Favourite
Find a datasheet?
EEWorld Datasheet Technical Support
Related articles more>>
    Copyright © 2005-2025 EEWORLD.com.cn, Inc. All rights reserved 京B2-20211791 京ICP备10001474号-1 电信业务审批[2006]字第258号函 京公网安备 11010802033920号
    快速回复 返回顶部 Return list
