Parallel high-speed current driver circuit diagram composed of OPA660
Source: InternetPublisher:newrudeman Keywords: Circuit diagram OPA current driver Updated: 2020/05/12
The figure shows a parallel high-speed current drive circuit . The input signal Vin is added to the base B (pin 3) of the equivalent special transistor OTA in the OPA 660 device through a 180Ω resistor . The two collectors C (pin 8) are directly connected and connected to the load, while providing current to the load. , so the current flowing through the load is twice that of a single OTA, because the maximum output current of the OTA in the OPA660 is ±15mA, and the maximum output current that the parallel circuit can provide is ±30mA. When larger current is required, multiple OPA660 operational amplifiers can be connected in parallel to obtain the required load current. The external 180Ω resistor at the input end (B pole) has a current limiting effect, which can also prevent the amplifier from self-oscillation and reduce the peaking phenomenon of the frequency characteristics. The negative feedback resistor RE (tens of ohms to hundreds of ohms) connected to the emitter can improve the linearity, input impedance and stability of the amplifier and many other dynamic indicators, but the transconductance of the OTA will decrease. It can be seen from this that, Appropriately changing the resistance of RE can adjust the output current.
- Voltage divider circuit calculation formula, where to find the voltage divider circuit?
- How are diodes made using semiconductors?
- Which one is better, NPN or PNP transistor?
- What does a rectifier do? What is the process of rectification?
- How does a series arrangement of Zener diodes affect the electrical behavior?
- This article will tell you the hard requirements of operational amplifiers
- Advantages and disadvantages of organic semiconductors, the conductive mechanism of organic semiconductors
- What are the parts of the fpga design process
- Circuit diagram of an example of differential and integral circuits
- FL52C4 induction electronic greeter
- Introducing the CD4013 washing machine timer circuit diagram
- Remote control circuit diagram composed of CSJ-T300B and CSJ-R02B
- Cycle timer circuit diagram with start and stop preset functions
- Circuit diagram of verbal rescue box for patients who have fainted
- Underarm odor treatment device circuit diagram
- Vehicle network electronic control unit circuit diagram
- Radio receiving circuit diagram of TA31136
- AC grid powered light emitting diode circuit diagram
- Delayed AGC principle circuit diagram
- Broadband operational transconductance amplifier buffer OPA660 circuit diagram
