FET high input impedance broadband amplifier
Source: InternetPublisher:小胖友 Keywords: FET wideband amplifier high input impedance BSP Updated: 2021/09/09
Field effect transistors have very high input impedance and can be made into high input impedance amplifiers. However, in field effect tube amplifiers
, the distributed capacitance and Miller effect capacitance at the input end have a great impact on high frequencies. In addition, as the operating frequency increases
, the input impedance of the field effect transistor will gradually decrease. Therefore,
it is impossible to obtain a high input impedance over a wide frequency range using a common-source FET amplifier without negative feedback . Therefore, to use field effect tubes to produce high input impedance
wide-band amplifiers, amplifiers with series voltage negative feedback should be used or source plate followers should be used. Figure 8-11 is a high input impedance wide-band preamplifier
composed of
field effect tubes and bipolar transistors . In the figure, the field effect transistor VTi forms a common source amplifier, and its drain
output is directly coupled to the base of the transistor VT2.
The collector output of VT2 is divided by Rs and R3 and fed back to
the electrode of VTi, forming Deep series voltage negative feedback
greatly improves the amplifier's frequency response and increases
its input impedance. According to the values of each component in the figure, the circuit's
voltage gain Kv=2.7, the output impedance is equal to 80n, and the passband
reaches several megaohms. Increasing Rs can increase the total
gain of the amplifier, and Kv can be greater than 100 times. But as K,, increases
, the frequency response decreases.
- What is the function of a voltage regulator in a circuit? How to connect a voltage regulator?
- What is a pure resistance circuit? What is a pure resistance AC circuit?
- What is an ac to dc transformer in circuit design
- The Importance and Ideal Model of Impedance Matching
- What types of power field effect tubes are there? Selection criteria for power field effect tubes
- FPGA Features and Architecture
- What is the difference between CPLD and FPGA?
- Transfer characteristics of BJT, how to apply Shockley equation?
- What types of force sensors are there?
- Purpose and composition of amplifier circuit: low frequency voltage amplifier amplifier circuit
- Excellent performance household inverter power supply circuit
- stuttering correction circuit
- Peanut and melon seeds roasting machine circuit
- Chicken supplementary light to increase egg production rate circuit
- Rural vegetable greenhouse lighting circuit
- Poultry warming temperature control circuit
- Integrated synchronous detector composed of analog multiplier MC1596
- Voltage controlled power supply second-order high-pass filter circuit
- Fault signal trip circuit
- Sine wave signal generator circuit
