Internal circuit structure of STKS0100
Source: InternetPublisher:elleny Keywords: Circuit structure ST BSP OCL Updated: 2021/05/18
ST K0100 thick film hybrid integrated circuit is an OCL type power amplifier output circuit that uses dual power supplies . Its characteristics
are good temperature stability, the quiescent current has temperature compensation characteristics, the gain of the circuit can be adjusted through the settings of the external circuit
, and the degree of freedom is high. The package has good heat dissipation and is easy to use. The
internal circuit structure of srKOl00 is shown in Figure 295. As can be seen from the figure, it is equivalent to the power output part of a typical OCL power amplifier circuit
. The circuit is very simple, consisting of only 5 transistors, 2 diodes and 5 resistors. oVTi and 1Ⅵ, Ⅵ≥, Rl,
R2 have temperature Output stage static bias circuit with compensation function, VT2 ~ VTs form a composite fully complementary push-pull output stage port
- Share a mini piano circuit
- Echo Dot speaker intelligent control system solution
- Simple and practical small amplifier
- DIY a stylish Bluetooth speaker
- Installation of electron tube differential amplifier circuit
- A simple and practical tube amplifier
- 1OW audio power amplifier circuit using UPC1238
- A common-phase audio power amplifier circuit powered by a split power supply using LM1877
- Single power supply audio power amplifier circuit composed of LM3875
- LM4820-6 audio power amplifier circuit
- Self-defense anti-riot circuit
- Pulse therapy circuit
- Egg warming circuit
- Agricultural small tractor lighting circuit
- Greenhouse temperature control circuit
- Soil water shortage prompt circuit
- Double detuned loop frequency discriminator circuit
- Integrated synchronous detector composed of analog multiplier MC1596
- Simple AGC circuit in transistor radio
- Broadband high frequency power amplifier circuit
