Really beautiful sound promotion module 01
Source: InternetPublisher:拿铁三分糖 Keywords: SAM power amplifier power supply voltage Updated: 2021/11/14
Internal circuit diagram of the SAM module. Modern high-speed
FET input devices all use similar circuits, such as OPA627. Figure 3-2 is the internal circuit of the HD AM module
of the Japanese Marantz Company. 6
HDAM can be said to be famous, and many of Marantz's high-end
CD players , PM15 advanced power amplifiers all use it. Comparing these two circuits, it can be found that the internal circuit of SAM has an extra stage of common
-base amplifier, that is, the input circuit is common-source common-base amplification, while HDAM is only common-source amplification. Due to the low withstand voltage and
small transconductance of the field effect transistor , the open-loop gain of HDAM is not large and can only be used in low-voltage situations.
The effect of replacing ordinary operational amplifiers is naturally superior. However, modern power amplifiers require high driving voltage and
small distortion, so HD AM is not suitable. SAM can withstand higher power supply voltages
. There are two types of SAM : one is type A; the other is type B. Type A is suitable
for small signal amplification, and the power supply voltage range is ±15V ~ ±40V; type B
is driven by the voltage in the power amplifier , and the power supply voltage Can be as high as ±ssv, output voltage swing only lower than the supply voltage
- Balcony intelligent invisible anti-theft net
- New function added to MF-47D multimeter - infrared remote control detection
- Analysis of valid and fault conditions of differential signals
- Fire detector made with photodiode
- 1.5V and 9V battery tester circuit diagram
- Application of TDA1514
- AC equivalent amplifier circuit
- DC power meter
- DS8 type 100V, 5A mutual inductance three-phase three-wire electric meter wiring
- Numerical control following or inverting circuit
- TW-42 ultra-short wave radio transmitter high frequency power amplifier circuit part
- 80Wx2 high-fidelity power amplifier
- DC power amplifier with simple circuit
- The simplest structure OCL power amplifier
- Production of high-quality active two-way constant current power amplifier 02
- Nx75W integrated power amplifier components
- 20W 40-500kHz power amplifier 03
- Simple and concise DC power amplifier
- Simple and supreme 200W fully symmetrical power amplifier
- Quasi-Class A HI-FI amplifier with excellent performance
