UDN2936 application example
Source: InternetPublisher:spectrum Keywords: BSP electric motor Updated: 2020/05/31
UGN3113U current collector open circuit switching
Hall integrated circuit is used as a position sensor. The current limiting circuit is equipped with a crystal camp V, and
takes R,=l. Skfl, R,=300CZ, rR=5V, R.=0.150. When V. When it is OFF
, the motor starts and the current is limited to 2A. Then control V. is ON. Operation
current limit is 0 67A.
The motor speed can be controlled by current limit , that is, adjusting the size of VI and FF to adjust
the speed.
- Controlling LEDs with Multithreading via Dual-Core Programming on Raspberry Pi using MicroPython
- What are the challenges in designing a permanent magnet linear generator?
- Motor self-starting circuit
- Simple phase failure protection circuit composed of intermediate relay
- IGBT modules block overcurrent by controlling the gate
- Hydraulic control circuit design and analysis
- Light-controlled circuit design and analysis
- Motorcycle anti-theft device circuit design
- Infrared detection alarm
- Car audio system anti-theft circuit
- Set timing circuit when power is on
- High-efficiency speaker circuit for rural stage
- Fish farming thermostatic control circuit
- Agricultural spraying and insecticide control circuit
- Soil water shortage prompt circuit
- Integrated synchronous detector composed of analog multiplier MC1596
- Diode balanced amplitude modulation circuit
- Color display circuit
- Guest arrival signal recognition circuit
- Digital stopwatch display circuit
