Refrigerator thermostat alternative circuit diagram
Source: InternetPublisher:ghaytweyhtoo Keywords: Thermostat refrigerator circuit diagram Updated: 2020/12/06
When the thermostat of the refrigerator is damaged and it is difficult to configure a new thermostat for a while, the electronic thermostat introduced in this article can be used as an emergency replacement.
The working principle of the circuit is as shown in the figure: it uses a time base integrated circuit NE555 as a cycle timing controller. When the power is turned on, since pins ② and ⑥ of IC 1 are low level, IC1 is triggered to set, and its ③ pin becomes high level. At this time, relay J is excited and closed, and its normally closed contact j1 is broken. On, R5 does not work. At the same time, the normally open contact j2 is closed, and the refrigerator receives power and starts cooling. At this time, because the ③ pin of IC1 is in a high level state, the diode VD6 is turned on, and the current charges C1 through the resistors R1 and R2. As time goes by, when the voltage at both ends of C1 rises to 2/3 of the power supply voltage, IC1 automatically resets. , its ③ pin becomes low level, the corresponding relay J also loses power and is released, and the refrigerator stops working. After stopping working, because the ③ pin of IC1 is low level, j1 is connected to R5 at this time. Due to the connection of R5, the threshold voltage of IC1 is not 1/3 of the power supply voltage, but 1/2 of the voltage of IC1 ⑤ pin. At this time, C1 is discharged through R3, R4 and the internal discharge tube of IC1. When the voltage on C1 drops to about 1V, IC1 flips and sets again, that is, the ③ pin of IC1 turns to high level again. Therefore, due to the access of R5, the smaller resistance values of R3 and R4 can obtain a longer delay, and at the same time, it can also reduce the difference in charging time between the first and subsequent times. According to the value of this schematic diagram, by appropriately adjusting R2 and R3, the startup and shutdown times of the refrigerator can be controlled to be about 5-15 minutes respectively. In order to extend the shutdown time of the refrigerator, the resistance of R5 can also be appropriately reduced.
ck="window.open(this.src)" alt="Click to see larger image" />
Component selection and production
No. Name Model Quantity R1 Resistor 470K 1 R2 Trimmer resistor 1.5M 1 R3 Trimmer resistor 680K 1 R4 Resistor 360K 1 R5 Resistor 1.2K 1 C1 Electrolytic capacitor 470u/16V 1 C2 Polyester capacitor 0.04u 1 C3, C4 Electrolytic capacitor 220u/25V 2 VD1-VD6 Rectifier diode IN4001 6 IC1 Three-terminal voltage stabilizing IC LM7812 1 IC2 Time base circuit IC NE555 1 J Relay 15A 12V Such as: JCZ-22F 1 T Power transformer power ≥5W 1 When using, it should be appropriately adjusted according to the changes in different seasons. Adjust the resistance of R2 and R3 to ensure that the minimum and maximum temperatures of the refrigerator meet the required requirements. Generally, the difference between the maximum temperature and the minimum temperature in a refrigerator should be controlled between 6-10°C, the start-stop ratio per hour should not exceed 8, and the time of each shutdown should be adjusted to no less than 5 minutes.
After the circuit is debugged, it can be installed in the plastic case, and the socket CZ can also be installed separately.
- How to choose the right level of integration to meet motor design requirements?
- The meaning and importance of circuit protection, common types of circuit protection
- How to build a simple tachometer using an infrared reflectance sensor
- DIY an electromagnetic levitation device
- Star-delta step-down starting control circuit for squirrel cage asynchronous motor
- Methods for Eliminating Noise of Brushed DC Motors
- Design and analysis of wire control circuit
- IGBT modules block overcurrent by controlling the gate
- Hydraulic control circuit design and analysis
- Car audio system anti-theft circuit
- Multi-channel patrol detection control circuit a
- Flashing wall light control circuit
- Water dispenser double sheet control circuit
- Car window control circuit
- Schematic diagram of motor PLC control circuit
- PLC chain alarm control circuit used in production process
- CPU input and output and memory control circuit
- Range hood detection control circuit
- Automatic sprinkler irrigation control circuit
- Voltage servo motor and control circuit
