555 variable width monostable circuit diagram
Source: InternetPublisher:两手空空 Keywords: monostable circuit circuit diagram trigger Updated: 2020/03/26
Generally , the output pulse width of a monostable circuit is a fixed value. As shown in the figure, this circuit uses the output pulse, after low-pass filtering and DC amplification, to close-loop control its 555 control end, so that when the trigger frequency increases, its temporary stable width is automatically reduced to reach the output waveform. The empty ratio remains unchanged.
C2 and R2 perform differential triggering on the input signal. When the input frequency is low, after the output is low-pass filtered by R3C3, its DC level is low, and is inverted by IC 2 and then added to pin 5 of 555. Because the Vc control level is high, the output pulse width is large. As the trigger frequency increases, the filtered DC level becomes higher, the Vc terminal decreases, and the output pulse width of the 555 becomes smaller. Such closed-loop control can keep the output duty cycle constant.
The parameters shown in the figure are suitable for the input frequency range of 500 ~ 5000Hz. When designing the circuit, it should be ensured that R1C1<1.1Tmin=1.1/f max, fm ax is the highest frequency of the input trigger signal.
ck="window.open(this.src)" alt="Click to see larger image" />
- What does a rectifier do? What is the process of rectification?
- How to identify common mode interference? Methods to eliminate common mode interference
- How do you calculate the value of capacitors in series? Why use capacitors in series?
- Simple Wired Spy Bug Circuit Built Based on IC741
- Make a flameless electronic candle using simple electronics and LEDs
- Tutorial on building a NOT gate using BJT transistors
- How to install the accelerometer
- Introduction of TDA4863J/4863AJ TV field scanning IC
- Make a simple AM radio with digital circuit
- Common electrical circuits: frequency-selective (bandpass) amplifier circuit
- Electronic frostbite treatment device circuit diagram
- Vehicle network electronic control unit circuit diagram
- Micro wireless FM microphone circuit diagram
- Wireless microphone circuit diagram composed of 9018 triode
- Measurement circuit diagram of differential pressure sensing bridge
- Ultrasonic receiver circuit diagram for echo detection distance
- Input status indication circuit diagram
- Fingerprint identification system circuit diagram based on FPGA
- 555 positive output monostable circuit
- Monostable circuit using TCA965
