Remote control circuit diagram with clear switches
Source: InternetPublisher:同住地球村 Keywords: switch circuit diagram remote control circuit Updated: 2020/10/22
As shown in the figure, the four-way remote control switch circuit adopts a ZS-01F memory self-locking bistable relay, so that the circuit can be turned on and off under the pulse signal output by the remote control receiving circuit. control function. However, this circuit also has such a problem: since the same remote control transmitting button is used to turn on and off the control circuit, sometimes misoperation may occur due to misjudgment, which is not allowed for some controlled circuits. Change the relay in this remote control circuit to another type of relay, and use two different buttons in the remote control transmitter to control the on and off of the circuit respectively. By achieving clear on and off control, misoperation can be avoided.
ck="window.open(this.src)" alt="Click to see larger image" />
- Analysis of the reasons why bow-tie antennas are preferred over microstrip antennas for 5G antennas
- FM microphone made by 9018
- Frequency modulation circuit for crystal oscillator stabilization in radio transmitter alarm
- DKl000R OOK 315 MHz Receiver Module
- XEl209 70~30 kHz Ultra-Low Power CMOS Transceiver
- R5 433.92 MHz Receiver Module
- Common RF receiving circuit design for toys (3 high-frequency parts)
- TR5100 FM 150~15 MHz transceiver
- RF2516 AM/ASK/OOK 433/315 MHz Transmitter
- MICRF500 FSK 1000~700 MHz Transceiver
- Causes of inductor whistling in DC/DC circuits and related solutions
- Complementary voltage switching class D power amplifier circuit
- Driver drowsiness alarm circuit
- Emergency braking circuit when accelerator is pressed accidentally
- Sock knitting machine fault shutdown circuit
- 8-way switching input interface circuit
- Rural vegetable greenhouse lighting circuit
- One light one switch lighting circuit
- Circuit schematic diagram of Y-△ starting three-phase induction motor
- Geographical structure of split-phase starting single-phase induction motor
