Rural vegetable greenhouse lighting circuit
Source: InternetPublisher:ghaytweyhtoo Keywords: lighting circuits switches lights Updated: 2020/02/21
The lighting circuit of rural vegetable grids is basically the same as the general lighting circuit in rural areas. However, due to the high temperature and high brightness in the greenhouse,
it is very unsafe to directly install 220V lighting lines into the greenhouse. Therefore, the power supply of rural plastic film greenhouses is first used. The electric pole leads the electric wire into a small room outside the greenhouse
. The power distribution board is installed at a height of 1. Sm. After entering the house, a knife switch , electric energy meter, fuse, switch lighting , etc. are installed, and then
the electric wire is set up to the vegetables. Inside the greenhouse. Rural areas with better conditions can purchase and install an automatic leakage trip switch so that the power cord passes through the switch and then
enters the greenhouse.
- Fire safety evacuation emergency signs
- Measurement and analysis of automatic emergency lighting circuit
- Six LED stereo VU display circuit built with IC LM3915
- Design and production of rain control and light control timing controller based on P87LPC764
- Driving circuit for driving light-emitting diodes by IR53HD420
- Lighting audio control circuit
- Infrared remote control dimmer light circuit
- Two-way electronic music doorbell circuit
- Bedside lamp controller circuit
- 6-digit cathode fluorescent triode display circuit
- The service life of some components of the switching power supply
- Principle circuit of current switching class D amplifier
- vehicle alarm circuit
- Electric iron power saving circuit
- Switching interface circuit in timing query mode
- Mechanical electric shock switch value conversion circuit a
- 1-O connection diagram of PLC
- Object detection alarm circuit with locking function
- Single pulse signal generating circuit c
- Lithium battery charger circuit
