Analysis of internal reset circuit diagram of microcontroller
Source: InternetPublisher:国民男神经 Keywords: Microcontroller power supply and other power circuits Updated: 2021/07/02
The principle of the reset circuit is to connect an external resistor and capacitor to the reset pin RST of the microcontroller to achieve power-on reset. Reset is valid when the reset level lasts for more than two machine cycles. The duration of the reset level must be greater than two machine cycles of the microcontroller. The specific value can be calculated from the time constant by the RC circuit.
As shown in the figure below, the microcontroller reset circuit is composed of two parts: key reset and power-on reset. Among them, the STC89 series microcontroller has a high-level reset. Usually, a capacitor is connected to the reset pin RST to VCC, and then a resistor is connected to GND. This forms an RC charge and discharge circuit to ensure that the microcontroller is on the RST pin when it is powered on. There is enough time for the high level to reset, and then returns to the low level to enter the normal working state. The typical values of this resistor and capacitor are 10K and 10uF. The button reset is to connect a switch in parallel with the reset capacitor. When the switch is pressed The capacitor is discharged, RST is also pulled to a high level, and due to the charging of the capacitor, it will remain high for a period of time to reset the microcontroller.
![143733540.JPG](http://www.eeworld.com.cn/circuit/upload/b46ffbbc8d21ee9f3958d633887ebb7f/eb8e00eb3a9ed84842d031ad19cf0482.jpg)
- How to Make a Soft Latch Circuit
- Benefits of Wide Bandgap Technology for Power Converters
- Introduction and principle analysis of switching regulated power supply
- Energy-saving motorcycle rectifier regulator
- Basic circuit description of adjustable voltage regulator LM317
- Dual forward converter schematic diagram
- A simple positive and negative power supply circuit
- Integrated regulated power supply with continuously adjustable output voltage
- MAX1811 Lithium Battery Charger Production
- Circuit diagram explanation: simple switching power supply circuit diagram
- Isolation technology that maximizes power efficiency and minimizes radiation
- Maintenance skills and common faults of switching power supply
- CNC machine tool and computer communication circuit diagram design
- Design of infrared communication circuit based on single chip microcomputer
- SPI interface and microcontroller interface principle circuit diagram
- Interface circuit design of SPCE061A microcontroller and fingerprint identification module
- Anti-interference circuit
- Driving circuit diagram
- Signal input circuit a
- MAX703 and 704 constitute a microcontroller monitoring circuit
