Interface circuit design of SPCE061A microcontroller and fingerprint identification module
Source: InternetPublisher:张小哥 Keywords: Microcontroller interface control interface circuit Updated: 2021/09/22
The SPCE061A microcontroller communicates with the fingerprint identification module OM-20 through the serial port. There is a standard full-duplex universal asynchronous receiver/transmitter UART inside the SPCE061A microcontroller. The UART's receiving signal Rx and sending signal Tx are shared with IOB7 and IOB10 respectively, which are special functions of port B. Since the serial port of the SPCE061A microcontroller uses TTL level, and the serial port of the fingerprint identification module OM-20 uses RS232 level, level conversion must be performed in order to achieve communication between the two. The RS232 standard is a serial bus standard officially announced by the Federation of Electronic Industries. The RS232 serial interface bus is suitable for communication distances between devices not greater than 15m, with a maximum transmission rate of 20kBps. RS232 uses negative logic to specify logic levels.
Discrete components or integrated circuit chips can be used to achieve RS232 and TTL logic level conversion. At present, the more widely used integrated circuit conversion devices, such as MC1488 and SN75150 chips, can complete the conversion from TTL level to RS232 level, while MC1489 and SN75154 can realize the conversion from RS232 level to TTL level. Figure 3.1 shows the interface circuit between the SPCE061A microcontroller and the fingerprint identification module OM-20. MAX232 is very sensitive to power supply noise, so a 1μf decoupling capacitor is added to Vcc. The capacitors C1, C2, C3 and C4 take 1μf decoupling capacitors to improve anti-interference. ability.
- How do I choose the gain of an operational amplifier?
- RISC structure and its advantages and disadvantages
- Analysis of Operational Amplifier Differentiator Circuit
- LM337 pin diagram and parameters, LM337 application circuit diagram
- What is the relationship between capacitance and impedance in an AC circuit? How do you calculate the impedance of a capacitor?
- In-depth analysis of energy losses in oscillation frequencies
- This article will tell you the hard requirements of operational amplifiers
- Causes and solutions for noise in digital Class D amplifiers
- What is the difference between CPLD and FPGA?
- How do you calculate the value of capacitors in series? Why use capacitors in series?
- Multifunctional low-power RX130 32-bit microcontroller, do you know?
- Microcontroller buzzer control program and drive circuit diagram
- Analysis of internal reset circuit diagram of microcontroller
- Stepper motor drive circuit composed of LB1836M
- Minimum system interface circuit based on AT89C52 microcontroller
- Interface circuit between 4-wire resistive touch screen and ADS7846
- Bidirectional DC motor control interface circuit
- Wiring of the power supply part of the microcontroller
- Servo motor control circuit
- M62430 typical applications
