Basic symbol of resistance
Source: InternetPublisher:柯南道尔 Keywords: Circuit diagram Updated: 2020/07/22
There are two international standards for fixed resistors. The common ones are shown in Figure 1 and Figure 2. The former is adopted as a national standard, while the latter is common abroad.
Early resistors were composed of ceramic cylinders and two lead wires. The main body of the resistor was mostly made of ceramic, with a carbon film on the surface. The resistance was adjusted by cutting the ring. High-power resistors were wound with alloy wires. For high-power resistors, metal films were used, but the cost was relatively high.
- How are diodes made using semiconductors?
- Which one is better, NPN or PNP transistor?
- Which TVS diodes are suitable for RS232/RS485 and Controller Area Network applications?
- This article will tell you the hard requirements of operational amplifiers
- Ideal characteristics of operational amplifiers/pin configurations/gain types/primary applications
- Classification and characteristics of operational amplifiers, classification and characteristics of operational amplifiers
- What are the classifications of filters?
- Touch circuit design and analysis
- LED lights that “drain” battery power
- Purpose and composition of amplifier circuit: low frequency voltage amplifier amplifier circuit
- Voice controlled flash LED light circuit diagram
- Cycle timer circuit diagram with start and stop preset functions
- Inspection circuit diagram for broken rotor bar of three-phase motor
- Electronic frostbite treatment device circuit diagram
- Long-distance FM transmitter circuit diagram made of high-frequency triode
- Fingerprint identification system circuit diagram based on FPGA
- Pressure measurement circuit diagram
- Internal functional block diagram of reset chip TLC77XX
- Four bedrooms and two living rooms circuit diagram
- Battery discharge protector circuit diagram
