OP07-27 pin function diagram
Source: InternetPublisher:柯南道尔 Keywords: Pin function BSP operational amplifier RS Updated: 2020/05/24
OP07 has low drift (maximum voltage drift 30 FLV, maximum temperature drift 0.6vV/aC), low noise (maximum
0.6 pLVp.P), ultra-stability (maximum 0.6yV/qC.month), and wide power supply voltage range (t3~ +18V) high-performance
operational amplifier . The parameters of OP27 are relatively close to OP07 (see table for details).
Their pin function diagram is shown in Figure LO-l, and the application circuit is shown in the figure.
When R3:R4, Ri=R2, OP07 forms a differential instrument amplifier, and the amplifier gain is determined by R3/RI.
Figure 10-2 and Figure 10-3 are two examples of common circuits of operational amplifiers. The circuit structure is
the same as that of a general operational amplifier.
This circuit can amplify the input signal of the sensor and convert it into a 4~20mA current output. The circuit is mainly
composed of an operational amplifier, a reference voltage source, and an output tube. The input voltage is amplified by the operational amplifier and driven by V. After passing through the sampling resistor R6
, it reaches the load resistor Ri. output in the form of current. The relationship between the output current and the input voltage is
/ou-r=(VIN×Rs/Rz +5Rs/R,)/R6
according to the parameters in the figure
/ourr=(16VlN/JOO) +4.O(mA)
- How are diodes made using semiconductors?
- Signal diode arrays/configurations, freewheeling diode operation
- Which one is better, NPN or PNP transistor?
- An article explains the working principle of the Wheatstone bridge
- What is a pure resistance circuit? What is a pure resistance AC circuit?
- FPGA Features and Architecture
- TL494 pin functions/configuration/ratings/operating conditions/layout diagram
- Important things to know about PCB routing and how to design the right routing for your PCB
- Summary of knowledge points of multiplexer
- Purpose and composition of amplifier circuit: low frequency voltage amplifier amplifier circuit
- Inpatient pager circuit
- Rural vegetable greenhouse lighting circuit
- Electrical schematic diagram of DC voltmeter input at non-inverting terminal
- Frequency modulator composed of NE566
- OTL low frequency power amplifier circuit
- Voltage-controlled voltage source second-order active low-pass filter circuit
- Guest arrival signal recognition circuit
- Digital stopwatch display circuit
- Small current generator circuit
- Sine wave signal generator circuit
