Automobile window automatic control circuit diagram
Source: InternetPublisher:公子李 Keywords: Automatic control circuit control circuit diagram Updated: 2020/08/11
Article source: Circuit Diagram House Release time: 2014-11-4 16:37:18 | 14 times read | 0 times recommended | 0 comments
![Automobile window automatic control circuit diagram](http://www.eeworld.com.cn/circuit/upload/253727096dcf37daa4fd6d993e0394ec/571ca382c8455638ca8d5da705ff83ff.gif)
Two half-bridge intelligent power driver chips BTS 7960B are combined into a full-bridge driver to drive the DC motor to rotate to raise or lower the window. BTS7960B is a high-current half-bridge integrated chip used in motor driving. It has a P-channel high-side MOSFET, an N-channel low-side MOSFET and a driver 1C. P-channel high-side switch eliminates the need for a charge pump. requirements, thereby reducing electromagnetic interference (EMI). The integrated driver IC has logic level input, current diagnosis, slope adjustment, dead time generation and over-temperature, over-voltage, under-voltage, over-current and short-circuit protection functions. The typical on-state resistance value of BTS7960B is 16mfl, and the driving current can reach 4.3A, so even in the cold winter, the safe start of the car window can still be ensured. Adjusting the size of the external resistor connected to the SR pin can adjust the MOS tube turn-on and turn-off time, and has the function of preventing electromagnetic interference. The 1S pin is the current detection output pin. The INH pin is the enable pin, and the IN pin is used to determine which MOSFET is turned on. When lN-1 and INH-1. The high-side MOSFET is turned on and outputs a high level. When IN=O and INH-1, the low-side MOSFET is turned on and outputs a low level. It is controlled by the 16-bit microcontroller XC164CS. The switching action of BTS7960B is used to regularly monitor the system status. Receive appropriate fault feedback signals and exchange fault information and key control information with the central body controller through the vehicle network (CAN bus), thereby displaying the fault content on the user interface in a timely manner and controlling the electric windows in real time. In order to avoid current spikes when the window motor starts. The soft-start function is realized by controlling the pulse width modulation (PWM) signal with a frequency of 20kHz on the lower arm switch tube.
- Sharing layout and tips for multi-rail power supply design
- Isolated two-wire current loop circuit (XTR101, ISO100)
- Constant current LED lamp driver circuit with soft start and anti-shock
- Switching power supply circuit composition and function introduction of each part
- Voltage-current converter constructed with XTR110
- An ultra-low output voltage regulator
- Integrated regulated power supply with continuously adjustable output voltage
- Production of backup power supply for cordless phone
- A low-cost, high-reliability battery charger for electric vehicles
- LM317T voltage regulation adjustable circuit diagram explanation
- Voice controlled delay LED light control circuit diagram
- Excellent performance household inverter power supply circuit
- Closed-loop control circuit diagram of single-ended forward converter
- Battery Powered Capacitive Sensitive Touch Control Circuit Diagram
- LED display control circuit diagram in the counter
- LAS6350 motor control circuit diagram
- Gantry milling machine variable speed starting control circuit diagram circuit
- Control circuit diagram of backup power supply
- DC motor forward and reverse control circuit diagram
- Control circuit diagram of two-speed motor
