Dual-channel amplifier circuit composed of LM4912
Source: InternetPublisher:spectrum Keywords: Amplifier Circuit Updated: 2024/09/14
As shown in the figure, this is the LM4912 dual-channel amplifier circuit. The left and right channel audio signals are input to the 1st and 5th pins of the LM4912 respectively, and are output from the 9th and 7th pins respectively after being amplified by the internal amplifier, and are added to the speakers of each channel through the coupling capacitor Co. The maximum power consumption of the amplifier is PDMAX = VDD2/2π22RL. (Output capacitor coupling mode). The 2nd pin of the LM4912 is externally connected to the shutdown control. When the 2nd pin is connected to VDD, it is allowed to work; when it is connected to a low level, it is prohibited to work, reducing the power consumption of the chip. The 3rd pin of the LM4912 is the mute control. When the 3rd pin is connected to VDD, it is prohibited to work to eliminate the "click-pop" sound caused by the conversion; when it is connected to a low level, it is allowed to work.
- Does lithium iron phosphate battery need a protection board? The correct way to charge lithium iron phosphate battery
- What is the difference between MOSFET and BJT? Which one is better between MOSFET and BJT?
- Analysis of the flow direction of transistor current
- Analysis of the basic principle of measuring resistance by bridge method
- The Importance and Ideal Model of Impedance Matching
- What is the difference between CPLD and FPGA?
- What are the parts of the fpga design process
- What is power factor and three ways to improve it
- Diode-based clipping circuit
- Basic characteristics/working principles and application circuits of tunnel diodes
- Isolated 4 to 20mA-RTD transmission amplifier circuit
- Gyro amplifier circuit
- Practical amplifier circuit c composed of operational amplifier LM386
- Common high input impedance buffer amplifier circuit
- The working principle of common collector amplifier circuit
- Three amplification circuits of junction field effect transistors - common gate
- Differential amplifier circuit
- Common drain amplifier circuit
- Added neutralizing capacitor tuning amplifier circuit
- A co-located stereo amplifier circuit powered by positive and negative symmetrical power supplies
