Working Principle and Application of Shaded-Shaped Inverter Circuit
Source: InternetPublisher:狂妄火龙果 Keywords: Inverter Circuit Updated: 2024/09/12
1. Principle
The principle of the screen-shaft split inverter circuit is shown in the figure above.
The unilaterally amplified audio signal is input from the IN terminal and added to the gate of the electron tube Vl. In the screen and cathode circuits of Vl, two load resistors R2 and R3 with equal resistance are respectively connected. After the audio signal is amplified by VI, two voltages of equal magnitude and opposite phases are output from the screen and cathode (from the Tl and T2 terminals) respectively, which drive the power amplifier electron tube to work.
2. Application examples
As shown in the figure below, the unilateral audio signal voltage is input from the IN terminal to the left triode grid (1) pin of the electron tube V1 (6H8C), and after amplification, the audio voltage is output at the screen (2) pin. This voltage is directly added to the right triode grid (4) pin. After amplification by the right triode, two equal and opposite excitation voltages are output at its screen (5) pin and cathode (6) pin respectively, driving the two power tubes of the power amplifier stage to work.
Among them, the left transistor screen (2) pin is connected to the right transistor grid (4) pin, the voltage of the right transistor grid (4) pin is +66V, the voltage on the cathode (6) pin is +70V, the grid (4) pin voltage is 4V lower than the cathode (6) pin voltage, that is, the grid bias voltage of the right transistor is -4V. Direct cross-coupling of the two tubes can reduce distortion. R5 and C3 are frequency compensation circuits.
- What is a quartz crystal? Quartz crystal equivalent circuit analysis
- What is the difference between single-phase and three-phase power? When is three-phase power required?
- In-depth analysis of energy losses in oscillation frequencies
- Principle set of zero-crossing detection circuit advantages and disadvantages
- How to read resistor color codes? Resistor color codes illustrated
- Capacitance detection circuit configuration, how to deal with low frequency and high frequency noise?
- Transfer characteristics of BJT, how to apply Shockley equation?
- Ceramic filter structure/working principle/characteristics/application
- What types of force sensors are there?
- What is a Demultiplexer
- 555 square wave oscillation circuit
- 555 photo exposure timer circuit diagram
- Introducing the CD4013 washing machine timer circuit diagram
- Simple level conversion circuit diagram
- 555 electronic guide speaker circuit diagram for blind people
- Circuit diagram of disconnection alarm composed of 555
- Analog circuit corrector circuit diagram
- color discrimination circuit
- Color sensor amplification circuit
- Level indication circuit
