AD574A Unipolar and Bipolar Input Circuitb
Source: InternetPublisher:难得正经 Keywords: Input circuit AD BSP Updated: 2021/07/17
AD574A is a high-performance 12-bit successive approximation. A/D converter can directly interface with 8-bit or 16-bit microcomputer bus. The analog voltage input
to AD 574A can be either unipolar or bipolar. The unipolar input analog voltage range is 0-1OV or
0-20V; the bipolar input voltage range is ±5v or 20V.
When unipolar input is used, the B IP OFF terminal should be connected to ov. The circuit connection is shown in Figure a. The BIP OFF terminal in the figure
is connected to ground through a 100n resistor, and the zero point can be adjusted through RP1.
For bipolar input, the BIP OFF terminal is connected to the +lov voltage, and the circuit connection is as shown in Figure b. The B IP OFF terminal in the circuit
is connected to the REF and OU terminals with +10V voltage through the 1000 resistor RP2.
- Capacitance detection circuit configuration, how to deal with low frequency and high frequency noise?
- RC filter explained in detail
- What is the difference between CPLD and FPGA?
- What are the parts of the fpga design process
- Causes of PCB deformation How to prevent circuit board bending and warping
- Important things to know about PCB routing and how to design the right routing for your PCB
- How to build a triangle wave generator using an op amp and discrete components
- What is the difference between JFET and MOSFET
- Experimental circuit based on 4040 binary adder counter
- Simple LED advertising light circuit
- strain sensor
- Thermocouple temperature measurement circuit
- Precision automatic temperature control circuit
- AD574 and RS-232C interface circuit
- AD574 and PC bus interface circuit
- AD574A Unipolar and Bipolar Input Circuitb
- Revolution or pitch counting circuit
- 80-channel AD590 temperature measurement on-off control circuit
- AD524 type precision instrument amplifier
- AD22103 type temperature sensor circuit
