Sensitive frequency demodulator (LM565, LM111)
Source: InternetPublisher:天天都吃好吃的 Keywords: Demodulator Updated: 2024/08/30
As shown in the figure, this is a sensitive frequency demodulation circuit. This circuit is composed of a phase-locked integrated circuit LM565, which can track frequency deviation in a wide frequency range. However, for signals with small frequency deviation, due to the small demodulation output signal, the drift of the voltage-controlled oscillator will cause the drift of the comparator working point and produce errors. In order to overcome the above shortcomings, this circuit has a DC regeneration part in the circuit, so it can also work stably for signals with small frequency deviation. In the figure, the demodulation circuit composed of LM565 and comparator LM111 is basically the same as the general frequency demodulation circuit. The difference is that the input signal of A2 pin ③ in this circuit is not taken from LM565 pin ⑥, but from the peak holding circuit A1. In the interval of the FM input signal, the output of A1 is low, so the holding capacitor C1 discharges through the low output impedance of A1 and maintains the signal peak. Using this DC regeneration method, although the voltage-controlled oscillator has drift, the output of the peak holding circuit can be tracked, so the comparator can work normally.
- Does lithium iron phosphate battery need a protection board? The correct way to charge lithium iron phosphate battery
- How do Zener diodes protect circuits?
- Causes and solutions for noise in digital Class D amplifiers
- What is the difference between CPLD and FPGA?
- Share an interesting LED decoration project
- Causes of PCB deformation How to prevent circuit board bending and warping
- Why use PWM? What are its advantages?
- What is the difference between high-side and low-side resistive current sensing
- Introduction of TDA4863J/4863AJ TV field scanning IC
- Common electrical circuits: frequency-selective (bandpass) amplifier circuit
- FTL-3032 integrated tuner-demodulator internal structure block diagram
- Ultrashort wave receiver circuit diagram of demodulator
- Frequency shift keying demodulator circuit 01 composed of NE565 and μA710
- Using NE560B frequency shift keying signal demodulator circuit
- Stereo demodulator circuit diagram
- Digital frequency shift demodulator circuit
- narrowband demodulator
- FSK demodulator B
- PLL circuit for AM demodulator
- Cordless telephone pilot oscillator and FM demodulator
