Variable Rate LED Blinker Circuit
Source: InternetPublisher:拳制龙 Keywords: LED Flasher Updated: 2024/09/03
The circuit of the variable rate LED flasher is shown in the figure below. By adjusting the 2.7kΩ potentiometer RP1, the flash frequency can be changed from zero to 20Hz. R1 and R2 are used to stabilize the duty cycle of the entire circuit, which can keep the LED brightness unchanged when the flash frequency changes.
- Analysis of the flow direction of transistor current
- What is a Half Wave Rectifier? Working Principle of a Half Wave Rectifier
- What is an ac to dc transformer in circuit design
- This article will tell you the hard requirements of operational amplifiers
- What types of power field effect tubes are there? Selection criteria for power field effect tubes
- RC filter explained in detail
- Why Do Amplifier Fuses Blow? How Do You Prevent Amplifier Fuses from Blowing?
- How to Build a Simple Temperature Indicator Circuit Using NTC and PTC Thermistors
- Circuit diagram of a differential amplifier circuit
- Circuit diagram of an example of differential and integral circuits
- 555 square wave oscillation circuit
- 555 photo exposure timer circuit diagram
- Introducing the CD4013 washing machine timer circuit diagram
- Simple level conversion circuit diagram
- 555 electronic guide speaker circuit diagram for blind people
- Circuit diagram of disconnection alarm composed of 555
- Analog circuit corrector circuit diagram
- color discrimination circuit
- Color sensor amplification circuit
- Level indication circuit
