Multi-stage output delay circuit
Source: InternetPublisher:柯南道尔 Keywords: Delay Circuit Updated: 2024/09/02
The figure shows a delay circuit with multi-level output. The circuit uses an operational amplifier as a comparator. When the voltage VE is applied to the non-inverting input of the operational amplifier A1, the voltage VC1 at the non-inverting input of the operational amplifiers A2, A3, and A4 will rise along the exponential curve. The voltage provided by the graded voltage divider is added to the inverting input of the operational amplifier. Therefore, at the moments t1, t2, and t3 when the input of each operational amplifier changes from zero to VB (power supply voltage), each output signal is flipped, thereby achieving the purpose of step-by-step delay of VA1, VA2, and VA3. Note that this circuit uses dual power supplies, namely positive power supplies VE and VB and negative power supply -VB.
- What is a self-locking circuit?
- DIY a simple fire alarm
- Homemade Bluetooth controlled car using HC-05 Bluetooth module to communicate with mobile phone
- Working principle of one Xipu STR soft starter controlling two motors
- Add one more component to improve the phase failure protection function
- Design and analysis of the principle of automatic power-off switch during power outage
- Design and analysis of a four-bit remote control component capable of remote reset
- Design and manufacture of three-phase motor protection circuit
- PIC microcontroller controlled remote anti-theft alarm circuit
- Ultra-short wave item left behind reminder alarm
- Simple timing control circuit
- Digital camera flash control circuit
- Electromagnet control circuit
- Digital current loop control circuit
- Bedside touch light detection control circuit
- Photoelectric detection output control circuit
- It is a 20 to 200ns analog delay circuit divided into 10 steps.
- Touch-type delay circuit using digital circuits (3)
- Simple TTL delay circuit (1) circuit diagram
- Solid State Open Delay Circuit Diagram
